Old 10-Aug-2012, 2:54 AM   #1
mckev25
Which indoor antenna for this poor TVFool report?
Hello All,
I generated the following report for my address:
http://www.tvfool.com/?option=com_wr...9900238d829558
I'm a newbie here, and a newbie to the antenna world. So any direction you can provide would be greatly appreciated. From the report above, it does not look like I will be able to receive too many stations with an indoor antenna. However, we are renting a house, and not looking to do anything extensive right now. We mainly just want an antenna that will give us a strong signal for the stations we should be able to receive, and possibly a few extras.
Right now, we just have a cheap Phillips antenna that receives all the stations we should receive, but does not generate a strong signal (to be expected). Based on the above report, would it be better to get an amplified antenna like the Terk HDTVa, or a non-amplified like the Mohu Leaf? Any other suggestions would also be appreciated.
mckev25 is offline   Reply With Quote
Old 10-Aug-2012, 3:28 AM   #2
Tv Reception.
Please make a second tvfool radar report with the antenna height at 25 feet above the ground.
It looks like it will take a antenna mounted above the roof to receive more Digital Tv stations/channels.
__________
For better reception and better antenna placement.
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc. ??
For better reception and better antenna placement .
If a apartment etc. , what floor?? , what is the top floor ?? , What directions are the windows ?? . What directions patios or balconies ??
_______________________
With Higher antenna height .
Looks like .
WITN , NBC and MyNetwork and Me-Tv and Local Weather.
WCTI , ABC and Live Well Network and This Tv.
WNCT , CBS and The CW Plus.
Will come into reliable reception range.
Old 10-Aug-2012, 4:22 AM   #3
mckev25
more info
Teleview,
Thanks for the reply. I live in a 1 story house with windows on all four sides. Mounting on the roof is not something we are looking to get involved with, as we have less than a year left on our lease. I'm looking to keep it simple with an indoor antenna. Any recommendations there?
Thanks again!
Old 10-Aug-2012, 6:15 AM   #4
Tv Reception.
Nothing for inside the house.
There are No Magic Tv Antennas.
If you will like to receive the listed Digital Tv stations/channels , try a Winegard HD7694P in the attic aimed at about 40 degree magnetic compass direction.
A much better location for the Tv antenna to receive those Weak Tv stations channels to the north east is , above the roof.
Here is a antenna mount that does not make holes in the roof , http://www.ronard.com/34424560.html , buy at http://www.solidsignal.com.
Also there is the common J mounts that the small satellite dishes are mount on.
