Old 7-Aug-2012, 3:55 AM   #1
newdeal
time for new antenna
need antenna suggestion for my area.I am looking at the hd7698p but is it more than I need for my area and would you suggest a rotor? If so which one. what about a amp maybe a hdp269
http://www.tvfool.com/?option=com_wr...9900332671fe6d
newdeal is offline   Reply With Quote
Old 7-Aug-2012, 7:28 AM   #2
Tv Reception.
A Winegard HD7696P antenna with No preamp , aimed at about 185 degree magnetic compass direction will receive All of network channels , NBC , CBS , ABC , PBS , FOX , The CW , My Network , ION , and -> Many More <- digital main channels and digital sub channels.
But the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box.
______________________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
_______________________________
As always , trees and tree leaves and buildings that are close and in the direction of reception will reduce or block reception.
Locate the HD7696P antenna where there is the least amount of trees and tree leaves and buildings in the direction of reception.
