Old 12-Dec-2010, 11:21 PM   #1
mutton-javelin
Rotors???#@$%????
Hi all. Thanks for all the info to date.
Anyone have any rotor recommendations? 1 wire vs traditional separate wire etc.
mutton-javelin is offline   Reply With Quote
Old 13-Dec-2010, 3:46 AM   #2
The one coax is very nice , the same coax that goes from the antenna to the tv. For maximum power transfer from the inside unit to the outside motor , use quad shield coax. http://forum.tvfool.com/showthread.php?t=460
Old 13-Dec-2010, 12:54 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
That Eagle-Aspen is a very unreliable rotator, as the amount of current that can be sent up the coax cable is very limited, and it won't turn a decent-sized antenna with any degree of reliablilty. You would be much better off using a separate rotator cable as used by a Channel Master 9521a or an AntennaCraft TDP-2. If you have a very large array, you may also want to consider using a Hy-Gain AR-40 instead, which is a much heavier-duty rotator at greatly increased cost.
Old 14-Dec-2010, 12:08 AM   #4
mutton-javelin
high cost is not a good thing, though I guess you get what you pay for. Those antennas with the built in rotors sound like throwaway equipment.
On a side note, how much gain is too much??? Do I need something to control signals from nearby stations? Is it possible to overload???
Will my TV explode
Old 14-Dec-2010, 3:16 AM   #5
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
As i remember from your TVFool.com report, you have fairly strong signals coming from the Needham towers, but not so strong as to jeopardize your TV sets. Just mount the antenna properly, and you'll be just fine.
Old 15-Dec-2010, 12:03 AM   #6
mutton-javelin
There is a Telemundo station close by, see below. Is that a problem?
http://www.tvfool.com/?option=com_wr...81a32cc453be41
Old 15-Dec-2010, 3:11 AM   #7
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Nope...LOL A TV tuner by itself can handle a lot of signal; preamplifiers handle much less...
