Old 11-Dec-2010, 10:12 AM   #1
drslingshot
Antenna suggestions for west ky zip code 42071
Heres the link to my map information http://www.tvfool.com/?option=com_wr...81a3fc780aba7a
Any suggestions for antenna type and height are appreciated. I have equipment and skill to install as needed with regards to height etc.
drslingshot is offline   Reply With Quote
Old 11-Dec-2010, 3:07 PM   #2
Most will suggest a rotator in your situation. That will work with a HD8200U, HD7084P or CM 3671. Channel 5 will be a challenge. Get the antenna as high as possible. Use a 7777 preamp.
If you want to avoid a rotor here's a second option:
Get one of the 2-69 antennas aimed at 110°.
Add a 91XG aimed at 328° and use an A/B switch.
Each antenna needs it's own preamp.
Old 12-Dec-2010, 12:12 AM   #3
I like that second option.
