Old 4-Aug-2012, 1:33 AM   #1
Geewhizpat
Looking for Antenna
Trying to decide on what digital antenna to purchase to bring in local stations...here's the report link....
http://www.tvfool.com/?option=com_wr...99005b5b944be3
Geewhizpat is offline   Reply With Quote
Old 4-Aug-2012, 2:10 AM   #2
Tv Reception.
For reception recommendation tailord to situation.
Is this a , house , town home , condo , apartmaent , mobile home , motor home or etc. ??
What directions do the windows face??
What directions are the patios/balconies??
If this is a apartment and etc . what floor?? , what is the top floor??
Old 4-Aug-2012, 3:00 AM   #3
From the information provided, it looks as if you'll need to mount outdoors. The bulk of the network programming is going to be coming the Sutro Tower facility. A Winegard HD7698P or, a combination of UHF-only (Antennas Direct 91XG or Winegard HD9095P) and High-VHF (Antennacraft Y10713 or Winegard YA-1713) joined with a UVSJ is indicated. A preamp such as the Antennas Direct CPA-19 is needed. Point toward 147° compass.
It's not clear if the stations indicated on CH-2 & CH-3 are on the air. If you have a desire to receive those signals, you'll need a Low-VHF capable antenna (Winegard YA-6260, Antennacraft Y526). Aim point would be determined by which signal you desired. A rotator may be desirable if two or more channels are operational in the CH-2 through CH-6 range. The 'Pending' version of your report suggests that a station may come up on CH-4 at some point. A HLSJ could be used to combine the Low-VHF signals into the common down-lead.
http://www.antennacraft.net/index.html
http://www.antennasdirect.com/
http://www.winegarddirect.com/
http://www.radioshack.com/product/in...ductId=2103923
http://www.solidsignal.com/pview.asp...nna-%28UVSJ%29
http://www.solidsignal.com/pview.asp...-%28ZHLSJ-1%29
http://www.3starinc.com/
http://www.rabbitears.info/market.ph...=K03IC#station
Last edited by GroundUrMast; 4-Aug-2012 at 3:44 AM. Reason: Low-VHF info + additional links
