Old 30-Jul-2012, 3:23 PM   #1
maconmatt
Complete Newb...will you analyze my OTA report?
I'm looking to ditch my DirecTV and start using an OTA setup. I really have no idea what i need, but ran a TVFool report.
Can any of you help me determine what setup/antenna would work best for me?
My report
Matt
maconmatt is offline   Reply With Quote
Old 30-Jul-2012, 4:55 PM   #2
A Winegard HD7694P pointed at 145° compass will provide reception of the major networks.
The antenna will perform best if it's not obstructed by trees or buildings.
http://www.3starinc.com/
http://www.winegarddirect.com/viewit...P%29&p=HD7694P
http://www.solidsignal.com/c/product...ennas-supplies
www.amazon.com
Old 30-Jul-2012, 4:59 PM   #3
maconmatt
Thank you!
Old 30-Jul-2012, 8:18 PM   #4
Tv Reception.
Important question --> How many Tv's are/will be connected??
http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Old 30-Jul-2012, 8:26 PM   #5
Tv Reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 31-Jul-2012, 2:03 AM   #6
maconmatt
We will only have 2 tvs connected...3 max.
Old 31-Jul-2012, 4:14 AM   #7
WPGA is rather weak... I think it's worth receiving though: http://www.rabbitears.info/market.ph...n=WPGA#station
Add an Antennas Direct CPA-19 preamplifier to the system and you should be able to enjoy that programing also.
Old 31-Jul-2012, 5:16 AM   #8
Tv Reception.
For 2 Tv's connected use a
HFS-2D , 2 way splitter.
For 3 Tv's connected use a
HFS-3D , 3 way splitter.
These splitters pass power form the power supply in the house to the amplifier part that is mounted close to the antenna.
http://www.hollandelectronics.com , also available at , http://www.solidsignal.com.
