Old 26-Jul-2012, 5:22 PM   #1
Olympicwatcher
Unhappy Need help on watching WVIT-DT NBC Connecticut
Dear All,
I am in Guilford, CT. Here is my signal report.
http://www.tvfool.com/?option=com_wr...99003cbc640671
Equipments are: bowtie antenna (DB8) in attic facing North, CM3414 signal amplifier, and CM7001 tuner.
Situations are: Got good signals from WEDH-DT (PBS) and WFSB (CBS) but NO signal from WVIT-DT(NBC), which is in the same dirction and distance of former two and report shows its signal strangth is in the same range of those two.
Because NBC has Olympic coverage, can anybody help me to solve this urgent problem? Thanks a lot in advance!
Regards,
Olympicwatcher
Olympicwatcher is offline   Reply With Quote
Old 26-Jul-2012, 5:28 PM   #2
Billiam
If you could mount the antenna on the roof you'd get a good signal. Is that possible?
Old 26-Jul-2012, 5:43 PM   #3
Olympicwatcher
Yes, possible. But why among three stations (PBS, CBS, and NBC) have almost same signal strength and from same direction and distance, only NBC dropped? Thanks!
Old 26-Jul-2012, 6:01 PM   #4
Relocate the antenna and try again. It's probably in a dead spot for that specific station.
Old 26-Jul-2012, 6:05 PM   #5
Olympicwatcher
I'll try tonight. Thanks!
Old 26-Jul-2012, 6:05 PM   #6
Billiam
That or multipath. I used to live in Simsbury and West Hartford and Ch. 30 was always ghosting when we had analog signals. Ch. 61 was always clear.
Old 26-Jul-2012, 6:17 PM   #7
signals unlimited
8 bay antennas can be very difficult to aim. If you have not yet tried moving left and right, do so around five degrees at a time, up to as many as 5 moves in both dirrections, one at a time.
Old 26-Jul-2012, 6:35 PM   #8
Olympicwatcher
Good info. Thanks! Actually I tried roughly to aim in W and N two directions and the latter gave me most channels. Looks I have to move it in smaller steps tonight. A long night...
Old 27-Jul-2012, 2:20 AM   #9
Tv Reception.
The DB8 is a Very Directional antenna in the forward direction , receives nothing on the sides and very little at the back of the antenna due to the reflector screens reducing reception to the >< shaped reception elements.
Your location has receivable Tv stations/channels , north , north west , west , south west , south and east.
A much better antenna for your location is the ANT751 mounted above the roof , aimed at about 0 degree magnetic compass (north).
The ANT751 does have some forward direction gain and is also not a very directional antenna so will receive the Tv stations/channels of the other directions.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com
