Old 26-Nov-2010, 8:02 PM   #1
Mikez
Help with stations to north & south
Hi,
I live right on the shore of Lake Michigan and most of my local stations come from Green Bay which is @ 40 miles away approximately 300 degrees azimuth. However, we also like a number of stations that are in Milwaukee and is due south about 70+ miles away over water and 180 degrees.
I was going to get a Channel Master 4228 and a antenna amp. But will this help me with stations to the south that are high up on the UHF?
Here's the antenna analysis: http://www.tvfool.com/?option=com_wr...81a32ea9a5ede7
Any suggestions would be greatly appreciated.
Mike
Mikez is offline   Reply With Quote
Old 27-Nov-2010, 3:33 AM   #2
Television Reception
Television transmissions spread this far apart in two separate directions means that a Tv antenna with a rotor or a two antenna solution with a remote control A/B switch. So the question is , how many tv's will be connected ? If one tv then a antenna with a rotor will be fine. If more tv's , then two antennas with remote control A/B switches at each tv. The 'Pending applications included' shows that WWAZ channel 5 is on the air now or will be soon. So to better understand the best antenna set up , how many tv's will be connected ?
Old 27-Nov-2010, 6:04 PM   #3
Mikez
Wow! I guess this going to get complicated!!
I plan on having three sets hooked up, with a possible fourth in th future.
So, I guess I'm game for a cool two antenna set-up.
How do I accomplish this?
Thanks,
Mike
