Old 20-Nov-2020, 7:12 PM   #1
02Lightning
looking for an antenna
Can anyone suggest one, going to mount front my chimney about 30ft. up.
http://www.tvfool.com/?option=com_wr...9038942d9d1039
02Lightning is offline   Reply With Quote
Old 20-Nov-2020, 10:22 PM   #2
Any four bay bow tie will work fine. (DB-4 or similar)
If you aim it between Dayton and Cincy, it should get both cities simultaneously.
Old 21-Nov-2020, 12:27 PM   #3
02Lightning
Thank you for the reply.
Old 21-Nov-2020, 12:48 PM   #4
02Lightning
Would I be able to pick up everything from the bottom shown in red up?
Old 21-Nov-2020, 10:26 PM   #5
Almost everything. The TVfool database is out of date. Daystar has moved to a low band channel which you would not get with a UHF only antenna. Try rabbitears.info fir an up to date channel assignment table.
