Old 11-Mar-2020, 7:19 PM   #41
MikeBear
Originally Posted by jp2code View Post
That means the channel search doesn't find it, and I have to push in 7.1 on the remote to see a bunch of static.
EDIT: Actually, it isn't static. People on here are too literal. The TV says there is no signal.
Can you run a brand new piece of coax up to the vhf antenna in the attic, and hook it directly to the vhf antenna only? Bypassing the UVSJ, and anything else.
Since it's on RF7, which is very susceptible to electrical interference and the like, perhaps that storm that caused it to go out actually damaged one of your power bricks, or some other device in your house. That might cause that device to still work yet jam the signal from this channel. I had this happen at my house, and a Dell laptop power brick in my living room, and also a Harbor Freight battery charger in my garage both were jamming my only VHF channel.
OR, did you around the same time install some new LED light bulbs, or a battery charger or the like? If so, try unplugging them one at a time, and see if the channel comes back.
As for "people on here being too literal", we have to be detectives, and since we don't get nearly enough useful info given to us up front, have to ask a LOT of questions hoping to get a reply that gives us an "Ah HA!" moment. There's so many different things that can be happening here, simply saying "it no longer works" tells us almost nothing useful.
Short of all that, I'd suggest buying the larger Stellar Labs VHF antenna, and replacing the old one.
Old 11-Mar-2020, 7:54 PM   #42
jrgagne99
I would take a TV up to your attic and test the antenna's output directly (short coax). Then work your way back, step by step with the TV, to find the bad component(s). It could be the UHF/VHF combiner.
Old 11-Mar-2020, 9:00 PM   #43
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
I'll give that a try. Summer hasn't kicked in yet, so it is still bearable in the attic.
I'll have to comb Craigslist for a cheap TV. I'm not dragging the 65-inch up there.
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
Old 12-Mar-2020, 1:54 PM   #44
jrgagne99
I have a portable handheld TV that works well for such things because it is small enough to take with you on the roof for signal hunting. It has a signal strength indicator setting with 5 levels. Not great but it is better than binary yes/no. Amazon has a bunch, but it is difficult to tell if they have a signal meter. Mine is a Haier I think.
Old 12-Mar-2020, 1:58 PM   #45
MikeBear
You can buy an RCA 19" tv set at Walmart for $74.95. Once you are done with it, you could likely sell it for the same price, or keep it for future use.
Tags
jp2code
