Old 12-Aug-2019, 1:26 AM   #21
Gophers
Got a couple of questions. I going to include pics. What type of coaxial cable do i have. Can't make it out. Also is that the right place for it. on the window and is the shades ok or will it cause problems. I need the shades down at night.
Gophers is offline   Reply With Quote
Old 12-Aug-2019, 1:38 AM   #22
If the shades are plastic they will have no significant effect on the antenna performance. If they are metallic they will have quite a bit of effect which will be frequency dependent. If the distance between the antenna and metal shade is just right, you may actually get a small boost in directional gain. If the spacing is too close or too far, you would expect reduced antenna performance.
The coax may be RG6 but I can't be certain.
Old 12-Aug-2019, 1:43 AM   #23
Gophers
The shades are plastic from what i can tell. Thank you for the reply.
Old 12-Aug-2019, 2:15 AM   #24
The Flex comes with a 3' RG6 coax that is to go between the antenna and the included inline amp as well as a 12' RG59 to go from the amp to the TV (or wherever).
Old 12-Aug-2019, 2:33 AM   #25
Gophers
I'm not using the coax cable that came with the flex. I'm using the one i had before. i believe it 50 Ft Coax Cable that i bought at walmart a while ago.
Old 12-Aug-2019, 2:51 AM   #26
OTAFAN
Just my 2 cents.
I would either use what came with your Flex, or replace it with a short RG6 jumper, say 15' or so. That way you minimize interference and maximize reception for your TV frequencies.
You can pick up a jumper of the size you need at your Walmart or big box stores or something like this from Amazon:
https://www.amazon.com/dp/B005NHIVO2...ter_B0787JNNXH
Either way the cost is minimal.
Here's an article on the difference between RG59 and RG6 that may be helpful:
https://sewelldirect.com/blogs/learn...n-rg59-and-rg6
Old 12-Aug-2019, 2:55 AM   #27
Gophers
I will check that out down the road.
Old 24-Aug-2019, 4:11 AM   #28
Gophers
Just wanted to give you guys a head up. The Sure Grip that came with the flex i had to take off. As it was wearing out. So i put some masking tape on the flex and window and that work out great for me. Also all channels still come in clear in morning, afternoon and evening. I also replace my 50 feet cable with a 15 feet cable. the 50 feet one was rg6. I got a 15 feet rg6 onn one. It working so far.
Old 24-Aug-2019, 4:10 PM   #29
The strips don't really "wear out". They do, however, pickup up any dirt, dust or lint that happens to be on the surface where it's placed. Eventually, they pick up enough that there's no more stickiness left. Remember the silicone "Wacky Wall Walker" toys? Same stuff, same issue. You can usually clean them and somewhat restore their function but eventually, they'll need to be replaced if you do a lot of moving of the antenna.
Anyway, contact customer service and we'll get a replacement strip sent out. See the contact address in my signature below.
Old 4-Nov-2019, 12:20 AM   #30
Gophers
Just to give you guys a update. I can now get 36 channels to come in on my antenna and everyone is coming in clear. So i love this antenna direct product. I'm not worry about the channels from IDS tower in Minneapolis. I love to get those. but won't worry about those.
Old 4-Nov-2019, 3:43 AM   #31
OTAFAN
Hi Again Gophers!
Good to hear about your updated report. Glad your Antennas Direct Flex is working for you.
What are those channels from the IDS tower in Minneapolis you might like to receive? Perhaps someone here on TV Fool would have an idea on how to catch those signals.
All the best.....
Old 4-Nov-2019, 10:41 PM   #32
Gophers
Those are low power channels. They are K33LN-D.
They have
33.1 Bounce TV
33.2 Court TV Mystery
33.3 Laff
33.4 Cozi TV
33.5 CBN News
33.6 3ABN
33.7 Grit
I know i most likely would need a outdoor antenna. But i'm not worry about getting those.
