Old 22-Jul-2017, 1:06 AM   #1
TX1228
Help with a new setup
So I've finally made the decision to cut the cord and would greatly appreciate any assistance as I go forward. The following information is requested in the sticky:
A link to a TV Fool report: http://www.tvfool.com/?option=com_wr...e6a4b7f1111abe
Existing equipment is a Dish satellite running about 40 ft from a shed to a 4 way splitter and then coax to individual rooms in the house.
I believe I can get everything I need from the channels from 165 to 170 degrees.
I would like to run from a single antennae to 4 or possibly 5 drops in the house. Also I would eventually like to use some sort of digital channel guide and DVR, preferably without a monthly subscription or one that would give me the most bang for the buck.
Thanks again in advance for any assistance.
TX1228 is offline   Reply With Quote
Old 22-Jul-2017, 12:09 PM   #2
JoeAZ
Is there some specific reason your dish is on a shed
40 feet from your home? What is your situation with
trees at 165 degrees??? Are the trees nearby??
No way to assess without more information.
Old 23-Jul-2017, 3:04 AM   #3
TX1228
Well it's actually a pump house for my well and that's where the dish is mounted because I didn't want the installer 10 years ago to drill into my new house. I'm not opposed to installing the antennae on the house though as long as I could do it without any chance of causing a leak in the roof.
No issues with trees to the South from 090 to 270 within at least 300 yds.
Old 23-Jul-2017, 12:28 PM   #4
JoeAZ
Thanks for the info. The ION station at only 8 miles is likely to
cause some challenges. It may overload your tuners, causing
the weaker stations to be unreceivable. The small, durable
yet capable Winegard 7694p costs just over $40.00 at Amazon
and HomeDepot.com To avoid any roof penetrations and leaks,
I'd use a "J" mount from MCM electronics but your old Dish
Mount would suffice quite well and save you money. Keep it
simple, especially at first. Purchase new RG6 cable, 50 feet
and run the cable from the antenna to one television through
a door or window. With one person holding the antenna and
the other watching the tv, either do a scan or check your signal
meter, if your set has one. You'll need to experiment and it
may take several hours to see where on your home you get the
best signal. You may just be better off with the Savannah
stations, even though that isn't your closest or home tv market.
Once you have your best signals and location, mount the
antenna. Don't forget to ground your system. It protects
against lightning and can enhance reception as well.
Do not use any kind of amplification, it will only cause problems.
Hope this gets you started.
Old 23-Jul-2017, 3:15 PM   #5
I agree with Joe that the Winegard HD7694P is a good choice and that you can't use a preamp because it will be overloaded by WPXC.
Try it first with just one TV, then add a splitter for the other TVs.
If WPXC is so strong that it is harming the reception of your weaker channels, you can try inserting a Channel Plus NF-471 Notch Filter to make WPXC weaker without doing too much harm to your other channels.
NF-471: Notch Filter
Removes CATV channels 75-80 and UHF channels 24-29
Notch filter frequency 529.25 MHz to 559.25 MHz
24 530-536 MHz
25 536-542
26 542-548
27 548-554
28 554-560
29 560-566
Par Electronics might make a filter to attenuate channel 24:
http://www.parelectronics.com/single-channel-tv.php
Tin Lee Electronics in Canada could also make one for you, but it would be expensive.
Old 23-Jul-2017, 8:29 PM   #6
TX1228
Thank you both for your time and recommendations. I also appreciate the advice for a mounting method. I'll start with this and see what happens.
If I do have to put in a filter to reduce the ION channel strength would that antenna still be sufficient to reach the other channels down that bearing that are approximately 50 miles out?
Old 23-Jul-2017, 10:01 PM   #7
If the tvfool report is correct, it should be OK down to WJXX.
If the filter makes ION weaker, then you will be able to use a preamp.
Mileage figures don't mean much; they are just marketing tools. What good is a "50-mile" antenna if you have a hill five miles away that is in the signal path?
What counts is the strength of the signal at your antenna.
Old 23-Jul-2017, 10:07 PM   #8
TX1228
Thanks Rabbit and Joe....one more question if y'all don't mind. How would this change if I were to go with an attic mount, or do you not recommend that at all?
Old 23-Jul-2017, 10:23 PM   #9
The 7694 has just enough gain for outside. If you put it in the attic, the signals would be weaker, but the attic loss is difficult to predict.
To find out, it would be necessary to try it.
PBS and ABC are in the red in your report. The tvfool FAQ says:
http://www.tvfool.com/index.php?opti...ask=view&id=57
Old 23-Jul-2017, 10:32 PM   #10
TX1228
Thank you....I'll stick with outside right now to keep things simple. Not sure I would watch PBS much, but I'd like to get all the major networks.
Old 23-Jul-2017, 11:24 PM   #11
rickbb
Another thing to think though is using the existing cable from the dish install.
Cable and dish installers are notorious for being poorly trained, low pay and just get it over with attitudes. (They get a flat fee for everything they do, and it's not much to start with.)
None of that matters with cable or dish reception because the signals are very strong and flat. So bad connections, long runs, etc, won't noticeably degrade your reception. I've seen installs from cable guys with 4 separate splitters piggy backed on each other. Totally killed reception at the 3rd and 4th TV when using an antenna even when the first TV got everything the home owner wanted.
Over the air reception is very much affected by such things as bad connections, long cable runs, number and type of splitters, etc.
Start with just one TV and as short a new cable as you can to find and fine tune where you put the antenna. Work from there to determine if and which cable run you can use and which ones you may have to replace.
Old 23-Jul-2017, 11:28 PM   #12
JoeAZ
An attic installation is always hit and miss as Rabbit stated.
A larger antenna, with more gain, probably wouldn't fit in
your attic. The recommended Winegard 7694P is really
sturdy and quite compact. It will handle Florida weather
and won't be an eyesore as well.
Old 24-Jul-2017, 1:35 AM   #13
TX1228
Thanks for the advice Rick and Joe...after looking into it more I think I'll be mounting it on the house vice the pump house so I definitely won't be using the DISH installed hardware, but good looking out and I agree with your statement.
Anyone have any experiences with using DVR's on an OTA setup?
Old 24-Jul-2017, 11:57 AM   #14
JoeAZ
While I personally don't have one, the Channel Master DVR+
seems to work well on installations I've completed. The tuners
are on par with most televisions. On the other hand, I've seen
and read about lots of issues with Tivo. The tuners have issues
with too weak or too strong signals. They seem to be unstable.
https://www.channelmaster.com/DVR_Pl...m-7500gb16.htm
Old 24-Jul-2017, 12:18 PM   #15
FWIW, we get lots of customer calls from both CM and Tivo customers where the TV set easily picks up stations that the DVRs have problems with.
YMMV.
Old 24-Jul-2017, 4:15 PM   #16
JoeAZ
YMMV.
Which one(s) do you recommend???
Old 24-Jul-2017, 4:38 PM   #17
I haven't found any of them that I'd swear by instead of swearing at.... but, I also haven't done much personal hands-on evaluations of them. I still have and occasionally use my Tivo Premiere from about 4-5 years ago and it does well, but it's installed a location that isn't complicated as far as reception is concerned.
Old 24-Jul-2017, 11:43 PM   #18
TX1228
So if I understand correctly the tuners associated with the DVR's aren't as robust as the tuners built into the TV's??? I never really considered that there was a significant difference between tuners.
Also, I understand that the antenna itself needs to be grounded and have no issues with that, but is a lightning arrestor recommended inline on the coax cable as well? If so, are there any recommendations or is one pretty much like the rest?
Old 25-Jul-2017, 2:39 AM   #19
It is possible to insert a coax surge protector, but a grounding block will satisfy the NEC requirement for an ADU (Antenna Discharge Unit).
Lightning strike density map:
http://forum.tvfool.com/attachment.p...9&d=1499441983
Old 25-Jul-2017, 12:24 PM   #20
Not at all, most tuners on the market use the same LG chipset. My suspicion is that the observed differences have more to do with the multi-tuner implementations that are going to include a splitter circuit and, perhaps, a "zero-gain" amplifier/splitter arrangement.
