Old 28-Aug-2015, 1:05 AM   #1
Irata
Looking to cut the cord and install an antenna
Guess that should be install a better antenna in the title.
Not sure if this is the right forum spot or not.
http://www.tvfool.com/?option=com_wr...8e03c9b03c21e1
I am hoping to receive signals from both Indianapolis, IN and Louisville, KY. I want both for NFL broadcasts as my team, more often than not, is on in one of the markets if not both. That would allow me to leave DirecTV and not pay for Sunday Ticket. Just as a side, I actually like DirecTV, I don't like my monthly bill.
Currently I have an AmazonBasics antenna and the amp that came with it. http://www.amazon.com/AmazonBasics-A...0290967&sr=1-4
It's mounted about 13-14' above the ground. Coax run to both TV's with this setup is about 75'. I have it facing SE/NW and I pick up several channels in Louisville clearly. My Tivo shows a signal strength of 55-60 on them. There is a corner of a house and some electrical lines in the path but otherwise very usable minus ION and ABC being glitchy on clear days.
I played with the signal meter and found it could recognize Indianapolis stations but the signal strength was only 15-30 with no pictures. That lead me to speculate (hope really) that with a better antenna for the distance and possibly raising it up that I might be able to get both. I'd prefer something that would allow all channels at the same time from both directions but I assume dual antenna would be required if so.
Been doing some research and was thinking maybe I could mount the antenna on the roof using an eave mount. That would add another 6 feet just to the roof plus however high the antenna is positioned about it.
Any suggestions on what would be the best solution or if this is possible?
Irata is offline   Reply With Quote
Old 28-Aug-2015, 1:52 PM   #2
rickbb
Generally speaking higher is better, there are exceptions and sometimes you need to move the antenna around AND up and down to find that sweet spot.
I don't know anything about that antenna, but just looking at the picture, I think you can do better with a known brand and roof mounted.
Mounting the one you have on the roof and adding an extension to the mast to get it higher won't cost much and might do what you want. A newer, (better), antenna won't cost that much either.
Old 28-Aug-2015, 2:24 PM   #3
That antenna is an Amazon-exclusive version of the Mohu Sky 60. It's only difference is cosmetic (the plastic housing). I've found it, at best, to be less than mediocre once the reception conditions start to become challenging.
Please create and post a new plot using your exact location as your initial plot is flagged as not being accurate (Google could not geocode your address) . Instructions are in http://forum.tvfool.com/showthread.php?t=14508
Old 28-Aug-2015, 2:42 PM   #4
Irata
http://www.tvfool.com/?option=com_wr...8e03e0da24271e
I hope this helps.
The AmazonBasics has worked well through spring and summer so far. Not the strongest of signals but the picture has been good. How does winter weather affect TV reception?
Old 28-Aug-2015, 4:29 PM   #5
With digital, all it takes is "just good enough" to have perfect or near perfect picture and sound quality. Digital cliff effect.
If your summertime reception was affected by seasonal foliage, that problem goes away until spring.
If you've been receiving sporadic out of market or distant reception during the summer, that usually goes away during the winter as the atmospheric enhancement effects subside and go away.
Realistically, reliable reception of the Indy stations at over 70 miles is probably going to be somewhere between extremely challenging and "ain't going to happen" even if you do everything right as far as antenna and amp selection, mounting site selection, and are able avoid any impairments in the immediate signal path out in front of the antenna. There are a lot of variables and the outcome depends on a number of things that may not be within your control such as buildings, trees, potential mounting height, willingness to deal with a very large antenna, and so forth. It's also going to depend on which of the Indy stations are going to carry the games that are of interest to you. Of course, and ESPN/NFL Network games won't be available with an antenna.
So, do you have a very clear line of sight to Indy? If not, you can expect reception to be negatively impacted.
Can you either handle a very large, 14' long antenna, or are you more in the camp that a smaller antenna with its lesser reception is the needed compromise?
Old 28-Aug-2015, 5:07 PM   #6
Irata
Well, I had hoped for better news. I planned to compensate with Sling TV for ESPN.
To be honest, I am not sure about LOS. I have not climbed up on my roof to see. For the most part from street level there is not really any obstruction it seems that direction.
I had resigned myself to the idea that a large yagi style was going to be needed to get Indy stations. If there is a smaller antenna that has the same kind of range that would be great.
On a side note, some of my neighbors have old OTA antennas on 30-40 foot towers that have probably been there since the 70's. I'm a bit jealous.
Old 28-Aug-2015, 6:35 PM   #7
rickbb
Picking the ABC from 70 miles to show to the profile shows you down in a RF shadow. Not looking good to get that channel. Might be why your neighbors have 30 to 40 towers.
WRTV-DT (Digital)
Channel: 25 (6.1)
Network: ABC
Maximum ERP: 1000.000 kW
Coordinates: 39.899068 -86.201017
https://www.tvfool.com/modeling/tmp/...RE-WRTV-DT.png
NOTE: The vertical dimensions in this profile have been exaggerated in order to make the terrain features more visible. This is merely an approximation based on the information available from the FCC database.
WRTV-DT
Effective ERP: 1000.000 kW (Adjusted according to your location)
Distance: 72.1 miles Azimuth: 12 degrees Compass: 17 degrees
Old 28-Aug-2015, 6:53 PM   #8
Irata
WRTV-DT (Digital)
Channel: 25 (6.1)
Network: ABC
WRTV-DT
Sorry to be such a noob with all of this but can you expand on what you mean? And maybe how to interpret the image on the details page?
Old 28-Aug-2015, 7:41 PM   #9
I'll try.
Here is the map:
If you click on a callsign in your tvfool report you will see the profile. The transmitter is at the left end and your location is at the right.
The black arc that you see at the bottom of the image is the curvature of the earth, which starts to interfere with the signal at about 70 miles.
The color code for the image is here:
http://www.tvfool.com/index.php?opti...id=15&Itemid=1
In very rough terms, the colors can be broken down as follows (not related to Antennaweb):
- White is extremely strong. Beware of signal overload on amps.
- Red-yellow-green are all quite strong. You can expect reasonable coverage with an indoor antenna.
- Cyan is where it's advisable to move the antenna up to the second floor or attic.
- Blue is where it's probably necessary to install a good antenna on the roof.
- Purple is quite weak and you really have to work at it for any chance of reception.
Here is the coverage map for WRTV ABC. You can see that the signal is pretty weak by the time it gets to your location. The color code is the same.
Old 28-Aug-2015, 8:46 PM   #10
Irata
I'll try.
Here is the map:
The black arc that you see at the bottom of the image is the curvature of the earth, that starts to interfere with the signal at about 70 miles.
Thank you very much for explaining that. I missed it on the site. This looks like I'd have to install an antenna tower for my best shot and cross my fingers I could pick up the signals.
Old 28-Aug-2015, 11:43 PM   #11
You are welcome. The fact that you were able to get some Louisville stations is promising. WHAS ABC real channel 11 from there could be received with better quality using a different antenna and a preamp. The Amazon antenna probably isn't very good for VHF-High channels 7-13. Unfortunately, ION is in a different direction.
Here is a close-up of the tvfool profile at your location that shows the colors better:
Another way to demonstrate the Indianapolis problem is to use elevation profiles:
adding the antenna heights:
but the earth isn't flat:
Old 29-Aug-2015, 1:06 AM   #12
Irata
Thanks. This is all a little disappointing. As a kid we had OTA until I was 12 or 13. Always thought we watched Indy channels so I was hopeful I could do this. I'd hate to spend a ton of money to install a tower and get nothing in return.
Where do I find these terrain charts?
Old 29-Aug-2015, 1:35 AM   #13
The Indy channels were analog then. You could watch them when they were very weak if you could tolerate a little snow. With digital signals it's all or nothing because of the "Digital Cliff," as ADTech mentioned.
The ones in color are ready made on the tvfool report. The black and white ones I created using this web site; it takes a little time to learn how to use their software.
http://www.heywhatsthat.com/profiler.html
I don't consider Indy to be impossible, just very difficult and expensive if you are willing to settle for unreliable reception and are willing to risk failure.
If you have a friend there he could stream it to you on the internet with a Slingbox.
Old 29-Aug-2015, 1:46 AM   #14
Irata
The Indy channels were analog then. You could watch them when they were very weak if you could tolerate a little snow. With digital signals it's all or nothing because of the "Digital Cliff."
Maybe I should write a nice letter to WRTV and ask them to raise their tower up a few feet for me.
I'll have to play with the site see how WXIN and WTHR look to my location.
Thank you!
Old 29-Aug-2015, 2:52 PM   #15
Irata
Thank you for all the work you did rabbit73. I can't consistently get ABC in Louisville and looks like even less chance out of Indy. Played around on the heywhatsthat page. I think I got it set right with the 2 stations of most importance (WXIN and WTTV) in relation to NFL games. WXIN seems to have the same possible issue as WRTV but WTTV looked to be a better possibility.
I'm going to ask the lady across the road if she uses her antenna. It looks newer (not all rusty as the two behind me across the alley) so she may actually use it.
Old 31-Aug-2015, 10:46 PM   #16
Irata
Just curious, given all the data in the thread does it look like I will need a tower mounted antenna to have a chance at Indy stations? Or would I have a chance with something like a DB8e mounted on the roof? Just looking for some expert suggestions on what I would probably need.
Old 1-Sep-2015, 2:13 PM   #17
rickbb
It would certainly be much less expensive to try a roof mount first. All you'd be out is the cost of the mount and a mast pole.
Old 6-Sep-2015, 2:35 AM   #18
Irata
This is where I had my Amazon antenna. My plan today was to move it to the top of the house:
This is what the SE facing part of the antenna perspective:
By the time we got everything in order it ended up being the afternoon. Unfortunately it was stupid hot today and the roof temp was ridiculous. So back to Lowe's for some conduit. We were able to approximate the height of the antenna on it's normal mount. (sorry bad picture) It's not done properly I know, this is completely temporary setup for testing purposes.
When we set it we put the flat sides directly N/S instead of NW/SE. I also added a preamp I found at Menards and removed the Amazon amp. This afternoon the weather was completely clear. Doing a check with the Tivo I still got all the Louisville except one AND the displayed signal strength went from 55-60 to 70 or above. I was able to add WTTV from Indy but none of the other channels came in then. They fluctuated up and down with no stable signal.
As of 10:19 tonight, WRTV, WTHR, WFYI, WNDY, WTTK, WHMB, and WXIN from Indy all coming in solid.
My plan is still to move it to the top of the but if I put the original short J pole on there will the roof affect reception from the north?
Old 6-Sep-2015, 2:34 PM   #19
Thanks for the photos.
What preamp did you get? Is it near the antenna or down at the lower end of the coax?
That sounds like a big improvement to me.
I'm not sure which way is north after looking at the photos. Which direction does the side of the house in the third photo face? Without knowing that, my answer is if the present location isn't affected, then the planned location will not be affected.
Ah, yes: I see towers in photo 2.
Old 6-Sep-2015, 4:04 PM   #20
Irata
Thanks for the photos.What preamp did you get? Is it near the antenna or down at the lower end of the coax?
The preamp is a RCA TVPRAMP1R. Relatively inexpensive so I figured I would experiment a little. I impulse buy. I have it mounted about 6 inches under the antenna.
About an hour or so later most of the Indy stations dropped off. Signal still good with the others though. At one point I had, for a few minutes, solid reception of channel 21 out of Fort Wayne which is 100+ miles away. That was weird.
That's the back of the house. It faces south.
I don't think either of those houses use those antennas.
I talked to the lady across the street with the antenna tower(not pictured). It's a bit shorter but only installed a few years back. Said it was never used and told me I could have it if I could get it removed safely.
