Old 11-Mar-2015, 4:40 PM   #1
tmbush
Need help with selecting Antenna
http://www.tvfool.com/?option=com_wr...f1f0c87041721b
tmbush is offline   Reply With Quote
Old 11-Mar-2015, 5:14 PM   #2
Google could not accurately resolve your address.
Please use procedure to generate a new report: http://forum.tvfool.com/showthread.php?t=14508
Old 12-Mar-2015, 1:54 AM   #3
tmbush
New TV Signal Analysis Results
Using the following procedure at (http://forum.tvfool.com/showthread.php?t=14508), the below new report was generated:
http://www.tvfool.com/?option=com_wr...f1f0dad3593d5c
Thank you for all your help,
Tracy
Old 12-Mar-2015, 5:17 AM   #4
Moderate sized antennas like the Winegard HD7694P or Antennacraft HBU-33 should offer very good reception if pointed NE and mounted outside. This assumes you can avoid aiming through trees or nearby structures.
To drive a couple of tuners through moderate lengths of coax should be doable without the need of a preamplifier. If you have over 100' of coax and are splitting to many TV's, a distribution amplifier such as the Channel Master CM-3410 can be added between the antenna and splitter after the fact.
Old 12-Mar-2015, 12:16 PM   #5
tmbush
Thank you GroundUrMast-
I plan on splitting to 4 TVs. The antennae wil be mounted on the back patio roof (replacing a directv dish) and plans to use the existing RG6 cable that runs to the attic, splits and then runs to each to tv. Is this doable?
Old 12-Mar-2015, 3:06 PM   #6
Is this doable?
If that dish location coincides with it being a "good" location for an antenna, then yes. However, if that location should result in the antenna aiming point-blank into your roof, your neighbor's roof, the biggest tree around, or whatever, then no.
Existing coax is perfectly compatible with antenna signals. It may be necessary to replace any satellite multi-switches with the equivalent splitter or, perhaps, a distribution amp.
Old 12-Mar-2015, 3:21 PM   #7
tmbush
Based on splitting the signal between 4 TVs, would the recommended antennae change?
What are your thoughts on the "Mohu Sky 60 Amplified Attic/Outdoor HDTV Antenna"?
Old 12-Mar-2015, 3:36 PM   #8
I summed those up in this very recent post (#2 in this other thread): http://forum.tvfool.com/showthread.php?t=15370
Old 12-Mar-2015, 3:42 PM   #9
timgr
The larger an antenna you use, the more "antenna gain" you get. There is no disadvantage to a too-big antenna for a given location, other than the physical size and wind load. You can use the added antenna gain to overcome the attenuation of however many splitters you want.
Antenna gain is superior to amplifier gain. An amplifier will always decrease the quality of the signal as it increases the amplitude. A bigger antenna will increase the signal amplitude with no loss in signal quality.
Be skeptical of little antennas with big claims.
