Old 7-Jul-2014, 5:12 PM   #1
billydee
How many channels could I expect with this setup?
Here's my TV Fool survey- http://www.tvfool.com/?option=com_wr...e1c6f6c4d79c14
I've already purchased and am planning to mount the Solid Signal HDB8X 8 Bay unit next weekend at a height of approximately 25 feet. If I can get it a little higher I will.
That said how many channels do you think I might get? I plan to point at both 109 and 342 degrees but there seems to be a few other stations in between those. Do I have any chance on picking those up?
Thanks in advance for any thoughts you might have.
Last edited by GroundUrMast; 11-Jul-2014 at 6:24 PM. Reason: restored original post per OP request
billydee is offline   Reply With Quote
Old 10-Jul-2014, 5:42 PM   #2
Based on the TV Fool report that you originally posted, I would expect you to be able to receive ABC, NBC, CBS, Fox, PBS and This networks. There may be a few others as well.
Old 10-Jul-2014, 5:52 PM   #3
billydee
Thank you for the info!
What the heck happened to my original post? I must have accidentally deleted it when editing?
I'll let you know what the final results are after the real antenna is mounted.
Old 11-Jul-2014, 5:44 PM   #4
It looks like you edited the original post. If you like, I can restore it.
Old 11-Jul-2014, 5:51 PM   #5
billydee
That would be great, thank you.
Old 11-Jul-2014, 6:24 PM   #6
done...
Cheers
