Place a , TERK HDTVi antenna (not HDTVa antenna) in/at the North East window.
Aim the HDTVi antenna at about 50 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas,
www.kyes.com/antenna/pointing/pointing.html
If the coax runs through the apartment from the antenna in the window to the Tv , then so be it because Reliable Reception is More Important then objections to coax running through the apartment.
Reception can be Tested without and witha , Winegard LNA-100 Boost amplifier.
Go into the the Tv Setup Menu.
The Tv Must Channel Scan for the , OTA=Over The Air , Antenna Channels , Air Channel , ATSC-Digital Broadcast Tv Stations/Channels.
DO NOT channel scan for cable Tv channels.
www.amazon.com
