Old 19-Feb-2014, 7:14 PM   #1
imjohnnykelley
Thumbs up Attic Antenna Needed
Hey there guys. I am cutting the cord and need some advice. I am renting a condo, and can't put an antenna on the roof or outside. I do have access to the attic though. Here is my signal analysis:
http://www.tvfool.com/?option=com_wr...5b94c53b81da0f
I am only looking to pull in the stations that are all in a line SW of me, so directional should be fine. Would be hooking into the existing cable splitter and going to 3 tvs. No really long runs (longest is under 30'). The attic isn't huge so I need to get something that isn't massive.
I know these aren't ideal conditions, but it is what I am stuck with. So what would be the best option for an antenna? Do I need an amplifier or anything else that I don't have right now? Would appreciate any help you can give me.
Johnny
imjohnnykelley is offline   Reply With Quote
Old 20-Feb-2014, 6:03 AM   #2
Attics and the Inside of Buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Begin the Reception Situation with a , http://www.antennacraft.net , HBU33 antenna in the attic aimed at about , 232 degree magnetic compass direction.
A antenna system amplifier will most likely not be required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
I reception situations/problems happen in the attic that are not resolved with antenna aim and location adjustments in the attic.
The move the HBU33 antenna to above the roof in such a manner that the reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of reception , South West , North East , East.
The main group of Tv transmitters are to the South West.
Here are some above the roof antenna mounts that do not make holes in the roof.
http://www.ronard.com/34424560.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com
Tags
antenna, attic
