Old 29-Dec-2013, 7:02 PM   #1
fkgrable@aol.com
Question Best Antenna
Please give me your recommendations for the best indoor and/or outdoor antenna based on the below analysis. My terrain is flat with trees being the only obstruction.
http://www.tvfool.com/?option=com_wr...46aec84b1780c6
Thanks
fkgrable@aol.com is offline   Reply With Quote
Old 30-Dec-2013, 4:48 PM   #2
elmo
So if you were to mount an antenna on the roof, what's the view to the east look like? That's where most of your good signal will be coming from, so the least amount of obstruction there will be good. A big leafy canopy can bust up the best of signals, especially on a breezy day. If you can go over them, that's good, but sometimes that's a big challenge in itself. If limbed up enough, you can possibly shoot under them, like through a small stand of pines. Distance between the antenna and the trees helps too.
Old 31-Dec-2013, 2:25 AM   #3
For reception of ->Many<- Digital Broadcast Tv stations/channels.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East , West South West.
Install a Antennas Direct DB8e antenna.
The DB8e antenna has , 2 , 4 bay bowtie antenna panels that can be aimed in any direction.
Aim 1 panel at about 90 degree magnetic compass direction.
Aim the 2nd panel at about 281 Degree magnetic compass direction.
Also install a Antenna Craft , Y10-7-13 antenna aimed at about 253 degree magnetic compass direction.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
For 1 or 2 Tv's connected a antenna system amplifier will most likely not be required.
The DB8e UHF antenna and the Y10-7-13 VHF high band antenna are connected together with a UVSJ=UHF/VHF antennas combiner.
The DB8e is connected to the UHF connection of the combiner.
The Y10-7-13 is connected to the VHF connection of the combiner.
The remaining connection of the combiner goes to the 1 Tv location or 2 way splitter.
This is the Combiner , EU385CF-1s , at http://www.solidsignal.com.
http://www.antennacraft.net.
http://www.amazon.com.
Looking at the Digital Broadcast Tvfool Current Plus Pending Applications Included Radar Plot and Channel List.
To the West South West.
You will be looking for reception of the weak signal strength , WKFK-LD VHF high band channel 13 , http://en.wikipedia.org/wiki/WKFK-LD.
And WMAH-TV , PBS.
And WXXV-TV , FOX.
Absorbing and Blocking Reception.
The Best Practice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Old 1-Jan-2014, 10:19 PM   #4
fkgrable@aol.com
teleview, elmo - thanks for your help.
Tags
antenna, indoor antenna, outdoor
