Old 30-Sep-2013, 2:08 PM   #1
TheNextFreud
Amateur needs the right antenna
Hello there. Ditched cable long ago, but feeling the need for the basic channels.
Here's the details:
http://www.tvfool.com/interactive/index.php
http://www.tvfool.com/?option=com_wr...46ae93ed83f573
-2nd story of a house, antenna could be wall mounted at 15 ft above ground.
-Have no equipment beyond my newer Samsung LCD TV
-Only looking to watch news and sports
What is the best/cheapest antenna that will work for me?
Thanks!
TheNextFreud is offline   Reply With Quote
Old 30-Sep-2013, 7:34 PM   #2
A Simple reception situation.
Above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception to the , North West , West , South West , install a ANT751 antenna aimed at about 265 degree magnetic compass direction.
_______________
Install a Winegard , LNA-100 'Boost' amplifier.
_______________
_______________
Check the Home Depot and Lowes stores or the ANT751.
http://www.solidsignal.com.
http://www.amazon.com.
_______________
Old 1-Oct-2013, 10:10 AM   #3
TheNextFreud
Further inquiry
I'm renting the apartment on the 2nd floor. It might be possible to mount the antenna outside, but if I were to mount inside, what that change your recommendation?
Thanks.
Old 1-Oct-2013, 10:38 PM   #4
The point is to get the ANT751 antenna Up High.
More reasons for having the ANT751 antenna Up High.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on broadcast Tv reception with a Tv antenna and so do buildings and other obstructions including the roof and building.
The Best Pratice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the roof and building.
_______________
If you will like to Test reception with a indoor type antenna.
For your location , install a Terk HDTVi antenna (Not HDTVa) in/at a ~West~ facing window or balcony door window.
Also install a Winegard , LNA-100 'Boost' amplifier.
______________
Window glass and pelxi glass offer little resistance to the reception of Tv transmissions so it is Best to have the indoor antenna at a location that has the Best reception.
The following is a -Non Complete- list of building construction that will reduce Tv reception More.
Walls , metal siding , metal backed insulation , metal roofs , metal doors , metal screens on the windows and doors , concrete , concrete blocks , bricks , rocks , and etc. and more , reduce the reception even more.
Old 2-Oct-2013, 12:32 AM   #5
TheNextFreud
Is it possible to just use this to test?
http://www.amazon.com/RCA-ANT111-Bas...ds=rabbit+ears
Old 2-Oct-2013, 5:39 AM   #6
Stereocraig
Yes, it is.
Tags
antenna, cable, channels
