Old 22-Aug-2013, 5:52 PM   #1
Segalhouse
Advice for attic antenna in Silver Spring MD
We would like to cut the cable, so I am looking for advice on a whole house antenna. We want to put the antenna in the attic, which is approximately 30 feet from ground level, and need some advice on what type of antenna, also do we need an amplifier. We will connect the antenna to four tv’s on three different floors in the house. These tv’s are currently hooked to cable so I believe we could use the existing coaxial cable is this correct? As far as channels go, we are hoping to get both the DC and Baltimore Network channels, basically what is in the green and yellow portions of our report.
http://www.tvfool.com/?option=com_wr...46ae8c955cce9f
Segalhouse is offline   Reply With Quote
Old 23-Aug-2013, 7:32 PM   #2
As Always , attic and inside of building Are Not reception friendly environment and Never Will Be reception friendly environment.
Yes start with a , ANT751 antenna in the attc aimed at about 62 degree magnetic compass direction.
Use a Old School magnetic compass.
_______________________________________
A antenna system amplifier is Not required.
For 4 Tv's connected use a simple common 4 way splitter.
____________
If reception situation/problems happen that are not resolvable by adjusting aim direction and location in the attic , then move the ANT751 antenna to above the peak of the roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , North East , East , South , South West.
________
As always , trees and tree leaves , plants and plant leaves , have a negative effect on broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
The best practice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or Antenna Channels in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
____________
Cable delivered services , cable tv , cable internet , cable phone , Can Not be connected to coaxes that are being used as the antenna system.
Do Not connect any type or kind of cable delivered service to the coaxes that are used for the antenna system.
Yes the coaxes that are in/on the house can be used for the antenna system.
However any type or kind of cable delivered service must be on separate coax.
_____________
Here are places to buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
Home Depot or Lowes will sometimes have the ANT751 antenna in stock , no matter what the Home Depot and Lowes web sites say.
Last edited by teleview; 26-Aug-2013 at 9:52 PM. Reason: Clarify information and typos.
Old 1-Sep-2013, 4:00 PM   #3
Segalhouse
Thank you for your response. Unfortunately the hubby is adamantly against putting the antenna on the roof. We went with an antenna ( Antennas Direct C2-V-CJM ClearStream 2-V Long Range UHF/VHF Indoor/Outdoor DTV Antenna with 20-Inch Mount) that gets great reception for the top level channels and are using it for our our two upstairs TV's the reception is not strong enough to service the first floor TV or the basement TV. Does anyone know if an amplifier would help?
Old 1-Sep-2013, 8:18 PM   #4
Mount a Channel Master CM-3410 distribution amplifier near the antenna. It will provide all the gain needed to overcome the loss in the cables and splitter.
