Old 30-Jun-2013, 11:02 PM   #1
js22
Need recommendations for antenna install please
Need help with antenna install as well as any recommendations for necessary equipment.
Here is my reception report
http://www.tvfool.com/?option=com_wr...0559956de45dc0
Antenna can be gable mounted on gable which is 22ft high.
There is a large stand of oaks to the south/south east of the mounting site about 50 to 60 feet away.
The house sits on a hill compared to the surrounding terrain.
Antenna will feed 3 TV's, the furthest being approx. 75 ft away from antenna through existing preinstalled coax cable.
Thank you in advance.
js22 is offline   Reply With Quote
Old 1-Jul-2013, 6:40 AM   #2
install a Antenna Craft HD850 All channel antenna above the peak of the roof in such a manner that the roof and house are not blocking reception to the south.
Aim the HD850 antenna at about 175 degree magnetic compass direction.
_________________________________________
http://www.ronard.com/909911.html. Use the 5 foot , ronard (911) , tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard (4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure the chimney and use a , ronard (2212) or ronard (2218) or ronard (2224) , chimney antenna mount.
Buy the ronard antenna mounts at http://sollidsignal.com or http://www.ronard.com.
No antenna system amplifier is required.
For 3 Tv's connected use a simple common 3 way splitter.
______________________________________________________
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennacraft.net.
________________________________________________________
For outside coax that is exposed to the weather/water use the coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To make double sure weather/water does not get into outside connections use http://www.coaxseal.com.
Do not use , rubber coax boots , the rubber boots take in water and hold the water inside , not good for connections.
As always , trees and tree leaves , plants and plant leaves , have Negative effect on Broadcast Tv reception and so do buildings including or own roof and house and other obstructions.
The Best Practice is to install the HD850 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Digital Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
