Old 3-May-2013, 8:49 PM   #1
AnonymousCitizen
Question Help! Am I S.O.L.
Okay, I'm way out in the middle of nowhere. Actually, about 30 miles outside of the middle of nowhere.
Do I have any hope of receiving any usable signals?
Here's the linky: http://www.tvfool.com/?option=com_wr...1dda61f9b68b29
(I would ask my neighbors if I had any nearby.)
AnonymousCitizen is offline   Reply With Quote
Old 3-May-2013, 9:44 PM   #2
The tvfool radar plot and channel list you have provide is not showing any antenna height feet above ground.
Do not delete the radar plot and channel list that is not showing any antenna height above ground.
To see if signal strength improves at higher antenna heights.
Make 3 more tvfool radar plots / channel lists at.
10 feet above ground.
25 feet above ground.
40 feet above ground.
________________________________________________
YES - the first 8 Tv stations will be received of the group of Digital Tv stations/channels at 46 degree magnetic compass direction.
And Yes a Large antenna will be required.
Old 3-May-2013, 11:17 PM   #3
AnonymousCitizen
That does look a little better when the antenna is not sitting on the ground.
http://www.tvfool.com/?option=com_wr...1ddac04939f634 (25 ft)
http://www.tvfool.com/?option=com_wr...1dda61f9b68b29 (40 ft)
Any specific antenna (model) recommendations?
Old 4-May-2013, 10:01 AM   #4
Ok I have been collecting and researching information.
Recommend install a Channel Master CM4228HD UHF antenna aimed at about 46 degree magnetic compass direction at about 25 feet above ground .
Aso install a http://www.kitztech.com.
Model KT-200-COAX TV Antenna Booster Remote Power-CoaxFed / Amplifier Booster.
The KT-200 Remote Power CoaxFed , provides the flexibility to install outside or inside.
____________________________________________________________________________
To keep weather/water out of outside connections.
Use coax that have the Compression type connectors on the ends of the coax , not the Old style crimp type connectors.
And to make double sure weather/water does not get into outside connections , Wrap with Coaxseal , http://www.coaxseal.com.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.amazon.com.
Here are some strong and sturdy antenna mounts.
http://www.ronard.com/Tripods%200703/4712.html.
http://www.ronard.com/909911 , use the 5 foot antenna mount.
http://www.ronard.com/34424560 , Use #4560 eave antenna mount.
http://www.ronard.com/ychim.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidignal search box or buy from ronard.
http://www.solidsignal.com.
http://www.channelmaster.com.
As always - trees and tree leaves , plants and plant leaves , produce the negative effects of , absorbing , multi-path/reflecting , blocking , Digital broadcast Tv reception and so do buildings and other obstructions including your own roof and house.
The tvfool report shows Your Location has 1 and 2 Edge Path obstructions = hills/mountains.
It is best to install CM4228HD antenna at a location that has the least amount to no amount of obstructions of any type or kind including your own roof and house.
______
The Tv/s Must Channel Scan for the Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
And scan for channels.
The following (of the tvfool channel list) are the Repeater Digital Tv Transmitters to the north east at 46 degree magnetic compass direction.
K16EJ-D REAL UHF Digital channel 16 , CBS and PBS channels and ABC and NBC.
K18FN-D Real UHF Digital channel 18 , FOX and Antenna Tv.
K14JZ-D Real UHF Digital channel 14 , PBS channels , MyNetwork and FOX and IND. .
K20FS-D Real UHF Digital channel 20 , ABC and Azteca America and LWN Live Well Network.
K26FM-D Real UHF Digital channel 26 , PBS channels.
K28FW-D Real UHF Digital channel 28 , MyNetwork and Me-Tv.
K30FO-D Real UHF Digital channel 30 , The CW and This Tv.
K32EX-D Real UHF Digital channel 32 , NBC.
Last edited by teleview; 6-May-2013 at 4:02 AM. Reason: Clarify information and typos.
