Old 2-Mar-2013, 12:38 AM   #21
North Ga
UPDATE-- Well I've got the antenna up 5 ft above the chimney, a good bit higher than it was..and pointed in the right direction. New problem- 2 - 11 channels have interuption that they never had before..11 was the only one that ever gave me trbl now 2 and 5 which are the abc and fox channels are messing up..What gives? Is there a way that the cable from the antenna could cause interference? I did bend it some to conceal it..I have put a Leviton 25 Db amp with FM trap..I get more channels with it but the above channels still scramble with or without it- any advice will be appreciated!
North Ga is offline   Reply With Quote
Old 5-Mar-2013, 9:20 PM   #22
North Ga
I got it- the vhf channels have to be pointed right on pretty much...that was what it was and maybe a little loose for a windy day..tighten down, and pointed in the right direction and back to really good signals!!
