As always , attics Are Not a reception friendly environment and Never Will be a reception friendly environment.
Yes you can start with Antennas Direct DB4e antenna in the attic aimed at about 170 degree magnetic compass.
Here is how to aim antennas ,
Do not use a preamplifier.
For 1 Tv connected use no splitter. No amplifier.
For 2 Tv's connected use a common simple 2 way splitter. No amplifier.
If there are reception issues on some channels then move the antenna to above the roof.
Here are some roof top antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronard.com/34424560.html ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
Here are some places to buy antennas and etc. ,
http://www.solidsignal.com ,
http://www.amazon.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channel , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
