A Simple reception situation.
Above The Roof install a ANT751 antenna with , no preamplifier , aimed at about 230 degree magnetic compass direction.
http://www.solidsignal.com , has a ANT751 antenna with a J type antenna mount , low dollars.
Here is how to aim antennas ,
For 2 tv's connected use a common simple 2 way splitter.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , north , west , south west , north east.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
