Old 15-Sep-2012, 8:08 PM   #1
morroco
Help please!
Ok i have been cable-less for quite a while but I would like to start getting whatever local channels I can. Can I get some help determining what antenna to use? TV fool data below, Thanks!
http://www.tvfool.com/?option=com_wr...5ed6117a8bf711
morroco is offline   Reply With Quote
Old 15-Sep-2012, 9:34 PM   #2
An RCA ANT-751 mounted high enough to 'see' over the roof line should be able to receive the signals NE & SW of your location.
If you have several TVs to connect it appears you would still have enough signal power to use just a passive splitter.
Old 16-Sep-2012, 12:58 AM   #3
morroco
Thanks!
I am on a hill with nothing much to the north of me; a few oak trees and a golf course, do you think an attic mount will work? (standard asphalt roofing). If not what directions/instructions do you recommend for roof mounting?
Old 16-Sep-2012, 3:42 PM   #4
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation fo broadcast Tv reception.
Install a ANT751 antenna above the roof.
Aim a ANT751 antenna at about 222 degree magnetic compass direction.
The ANT751 receives good at the , front - front angles and back - back angles ->This is the same directions that are required to receive at your location.
http://www.solidsignal.com , has a ANT751 with a J type antenna mount , low dollars.
For 1 Tv connection use no splitter , no amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no amplifier.
For 3 Tv's connected use a common simple 3 way splitter , no amplifier.
For 4 Tv's connected use a common simple 4 way splitter , no amplifier.
________________
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your house.
It is best to install the ANT751 at a location that has little to no obstructions of any type or kind in the directions of , north / north east , west / south west.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissons travel through the air from the transmitting antenna to the receiving antenna.
