Old 14-Sep-2012, 5:13 AM   #1
Jonskiv
Zero channels
My new Analysis plot: http://www.tvfool.com/?option=com_wr...5ed606f0dba205
Using a Winegard FV-30BB to HD home run and getting 0 channels after scan.
I've tried pointing from 150-185 deg.
In our previous home I mounted in attic and got 12 or so channels on this old analysis plot:
http://www.tvfool.com/?option=com_wr...5ed6e4e6522733
Any ideas to try?
Jonskiv is offline   Reply With Quote
Old 14-Sep-2012, 7:14 AM   #2
If the antenna is in the attic, it's low gain, building penetration loss and the terrain are all combining to leave you with little hope for reliable reception.
The single most effective improvement would be high mast or tower mounting, outside in the clear. It would be interesting to see a TV Fool report for 40' and another for 60'.
The signal conditions shown in your current report call for an outdoor mounted antenna that has substantially more gain. I would consider a Winegard HD7696P or HD7698P at a minimum. There are other 'premium' solutions that can be suggested if you'd be willing to consider a multiple antenna / multiple HD HomeRun installation.
http://forum.tvfool.com/showthread.php?t=820
Old 14-Sep-2012, 1:58 PM   #3
Jonskiv
Thanks for the prompt reply.
Here are my plots for 20 and 40 respectively. To my untrained eye difference seems pretty small. Unfortunately HOA may have issues we me putting up a large mast
http://www.tvfool.com/?option=com_wr...5ed6711b35fd5d
http://www.tvfool.com/?option=com_wr...5ed64791509775
Old 14-Sep-2012, 3:11 PM   #4
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
As always , HOA's , Housing Coven-nuts and etc. have no say about the size of the antenna or location of antenna on your property.
Here is the Federal Antenna Law that says Yes you can , install , use , maintain , Tv antennas of Any Size.
http://www.fcc.gov/mb/facts/otard.html.
HOA's , Housing Coven-nuts and etc. , are well aware of the Federal Antenna Law.
Old 14-Sep-2012, 3:45 PM   #5
Above The Roof , at no less then 20 feet above ground and 40 feet is better , install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 313 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best locate the antenna at a location that has the least amount to no amount of trees and tree leaves and buildings or other obstructions in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 14-Sep-2012, 3:54 PM   #6
If you prefer reception of the Tv stations/channels to the , south , south east , then aim the antenna at about 145 degree magnetic compass direction.
Old 16-Sep-2012, 7:15 AM   #7
Jonskiv
Thanks teleview. I'll try these suggestions.
Old 16-Sep-2012, 2:44 PM   #8
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The following is a Teleview recommendation fo broadcast Tv reception.
The following recommendation is a Channel Surfing Friendly way to receive both directions.
Install 2 Separate antenna systems , one aimed north west and one aimed south/south east.
The 2 Separate antenna systems are separate all the way to the location/s of the Tv/s and are connected to a A/B coax antenna switch at each Tv location.
Press the button on the hand held remote control , change antennas and keep on channel surfing.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
