Old 17-Dec-2010, 1:48 AM   #1
Hamosia
Which antenna?
I was wondering what my best options would be to get most of these channels?
I have a 30 foot tower, and I have 20 feet of poles I can use. So I guess my question is what antenna/antennas should I use to get these channels?
Thank you,
Adam
http://www.tvfool.com/?option=com_wr...da32b33ffc04c6
Hamosia is offline   Reply With Quote
Old 17-Dec-2010, 2:14 AM   #2
Tower Guy
Y10-7-13 for VHF 91XG for UHF. Aim them at 178 degrees. Put the 91XG higher than the VHF antenna. Use a 7777 preamp to combine and amplify the signals. Fox and CBS will be weak, but should work fine.
Do you know what's on the LPTV channels?
Old 17-Dec-2010, 5:31 AM   #3
Hamosia
I was`thinking about using the Y10-7-13 for VHF 91XG for UHF antennas, after reading some other posts. I just wanted to have a second opinion.
As for what's on the LPTV channels? I have no idea!? I am new to Alaska, only been here a couple of months.. I will let you know when I get my antennas.
Thanks for the help
Old 17-Dec-2010, 4:07 PM   #4
Usually, you can Google the LP station's call letters and find either a Wiki entry or some other description of what programming, if any, is on them
The majority of that category of stations are often religious, ethnics, shopping, or some similar type of content that is of interest of a narrow segment of the public. Sometimes, they're used as translators or for original local content.
Old 17-Dec-2010, 5:23 PM   #5
Dave Loudin
rabbitears.info will help identify the digital LP stations.
Old 9-May-2012, 9:41 PM   #6
Hamosia
Antenna help again
Would the Y10-7-13 for VHF 91XG for UHF, still be the best choice for my address? I have been using a used VHF/UHF antenna, that was given to us, so we did not buy the 2 separate antennas. We were able to get all the channels, except Fox, so we were happy for the time being. This last winter we had too much snow ice build up on the antenna and bent part of my tower down, and busted the antenna. So were in the market for a new antenna/antennas.
Thank you for any replies,
Adam
Old 9-May-2012, 11:30 PM   #7
Electron
Tv Antennas and Tv Reception
Install a Winegard HD9095P antenna and a Winegard YA1713 antenna .
Combine the two antenna with a Antennas Direct UHF/VHF Antenna Combiner that is in a weather protected housing.
The output of the antenna combiner is connected to the New and Improved Channel Master CM7778 Preamplifier.
Aim the antennas at about 158 degree magnetic compass.
Here is how to aim antennas , http://wwwq.kyes.com/antenna/pointing/pointing.html
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.antennasdirect.com , http://www.channelmasterstore.com.
Here are high quality light weight aluminum layover towers. Do antenna installation and adjustments standing on the ground. http://www.palcoelectronics.com/pe300.aspx.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
