Old 14-Apr-2012, 4:04 PM   #1
TOOLMAN
Help picking an antenna
Antenna will be mounted aprox 25ft above ground on top of roof & its quite windy mainly want the basic channels 3,10, would be nice to get 27,33 maybe 21 as well. Thanks! http://www.tvfool.com/?option=com_wr...3616888c2ff5a4
TOOLMAN is offline   Reply With Quote
Old 14-Apr-2012, 4:57 PM   #2
Tv antennas and Tv reception
How many tv's are/will be connected??
Old 14-Apr-2012, 6:16 PM   #3
Ok this will be a 2 antenna set up. The first antenna is a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp aimed at about 301 degree magnetic compass. The Tv stations/channels that will be received are , KSPR-DT channel 19 ABC and The CW , KYTV channel 44 NBC and Weather , KOZL-TV channel 28 IND. , KOLR channel 10 CBS , KOZK-DT channel 23 PBS. . The second antenna will be a Winegard YA1713 antenna with a Antennas Direct CPA-19 preamp. aimed at about 235 degree magnetic compass. The Tv stations/channels that will be received are , KEMV channel 13 PBS , K07XL-D 7 RTV and Antenna Tv and This Tv and Me-Tv. The 2 antennas and 2 preamps are 2 separate systems and are Not connected together on to one coax , the 2 separate antenna systems coaxes will go to the location of the Tv and will be connected to a Radio Shack # 15-1968 remote control A/B antenna switch and the output of the A/B switch is connected to the Tv. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
Old 14-Apr-2012, 7:03 PM   #4
TOOLMAN
I will use two tv's but wasn't planning on two antennas just suggest antenna for picking up channel 10 my old anntenna seen better days & needs replace it still picks up channel 3 & 38(fuzy but local christian station) I have an awsome 55"lg smart tv but miss the local channels. Thank you for responding so prompt!
Old 14-Apr-2012, 7:05 PM   #5
You can install the HD7698P and CPA-19 preamp and receive , NBC , ABC , CBS , The CW , Independent station , KOZK PBS. And use a antenna rotor CM9521A to rotate the the antenna to receive , K07XL RTV and Antenna Tv and This Tv and Me-Tv , KEMV PBS. However rotors are not channel surfing friendly and not every one will agree with where the antenna is pointed. You can start with the HD7698P antenna and CPA-19 preamp and install the YA1713 with CPA-19 preamp later.
Old 14-Apr-2012, 7:13 PM   #6
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/43324560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the antenna mounts at sollidsignal by typing the word ronard in the solidsignal search box or buy from ronard. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.antennasdirect.com , http://www.amazon.com. http://www.radioshack.com in the radio shack search box type in 15-1968.
Old 14-Apr-2012, 7:14 PM   #7
TOOLMAN
Oh I see. Ok but when I looked up the last entry posted on radio shack #15-... there are only 3 diget id's will you check that entry & I will continue to prosses the rest. Thank you!
Old 14-Apr-2012, 7:17 PM   #8
The Tv Must Scan for the Digital Broadcast Tv channels sometimes called the 'Air Channels" or 'Antenna Channels' in the Tv menu because the Tv transmissions travel through the air from the transmitting antenna to your receiving antenna. Do Not scan for cable Tv channels.
Old 14-Apr-2012, 7:20 PM   #9
TOOLMAN
Thank you sir I may be checking back at a later time with more questions.It's been a pleasure!
Old 14-Apr-2012, 7:29 PM   #10
Digital Broadcast Tv Channels have a main digital channel and digital sub channels , so the HD7698P antenna will the digital main channel and the digital sub channels. I provided the information of the Tv stations main digital channels and digital sub channels. An example is KSPR-DT channel 19 , the main digital channel is ABC the digital sub channel is The CW.
Old 14-Apr-2012, 7:33 PM   #11
If you are still living in the PAST when there was only one Analog channel per channel , those days are gone. This is now digital , digital can put more then one digital channel in the place/space of one analog channel.
Old 14-Apr-2012, 7:41 PM   #12
If you are looking for the easy way out , you are setting your self up for the antenna scammers. There many money hungry people on the internet that flat out do not care about you. They will take your money.
Tags
advice
