Hi all, I've been plagued by sporadically spotty TV reception for a while and I'm hoping someone can help me rule out some of the possible culprits before I spend a bunch of money solving problems I don't have.
You'll probably laugh when you look at the
TVFool Signal Analysis, since this should probably seem close to ideal, but here it is anyway.
The only things I really care about are the first 6 entries on the list which are all green. Every single one of them is:
within about a 9 degree spread
< 5 miles away
full LOS
> 70 dB NM
> -18 dBm Pwr
No co-channel warning
No adjacent channel warning
All UHF except Fox which is channel 7
If you look at the signal analysis, the entire plot is basically red, because I also live at the top of a decent sized hill.
Should be easy, right? Here's the rub. My antenna currently sits by a window that's basically the exact opposite side of the house that the signals are coming from.
I also realized way after the fact that my primary antenna (
Zenith Silver Sensor Indoor Antenna) is only supposed to be tuned for UHF, and fox is on VHF7, but I usually get pretty decent reception on it. It's getting my computer to give me a reliable picture on KXAN, KVUE, KNVA, and KEYE that seems to be my real problem.
My current equipment setup (from source to destination):
Choice of Indoor Antenna (Previously mentioned Silver Sensor, old Rabbit Ears,
~25 feet of RG-6 (didn't measure, I just know it's more than I really need)
3-way splitter feeding 3 of the following 4 (RCA from Home Depot?)
\RG-59 -> VBox Cat's Eye 150 (ATSC Tuner Card for my PC) #1
\RG-59 -> VBox Cat's Eye 150 (ATSC Tuner Card for my PC) #2
\RG-6 -> SiliconDust HD HomeRun (dual tuner for my PC)
\RG-6 => Dish Network VIP 722 (normally not connected, but I can use it for testing)
All tuner cards are plugged into an HTPC running Windows 7 and Media Center.
I never really use the Dish DVR for watching OTA broadcasts since there's no useful guide information, but I've used it for testing on a few occasions. All of the channels seem to come in fairly well on the Dish DVR with a rated signal of 60-75 (presumably out of 100), but I've never really tried it for more than 10-15 minutes.
On the HTPC, I usually get a good signal when testing, but then the same channel after a while (days? hours?) will go through periods of stuttering. The HTPC has plenty of relatively new parts and is fairly overpowered for its purpose so there should be no real hardware limitations.
When testing in things like the SiliconDust HDHomeRun app, which uses 3 criteria, I see:
signal strengths well above 90%
signal quality anywhere from 65-95% (occasionally dropping to the 60s)
symbol quality usually a solid 100%
Given my location, could I be in danger of being overpowered? Should I try an attenuator?
The chart doesn't seem to think so. Is it possible that I've got multipath issues from the antenna being in a bad spot of my house? It's a bit frustrating to tweak the antenna position and feel like I've got great reception only to have it get choppy 24 hours later with a clear sky in the middle of a football game.
I also picked up a
RCA ANT 1400R flat antenna yesterday just to try it out, but I haven't gotten a chance to plug it in and see if this would be any better.
Given my suboptimal window locations, should I even bother trying a larger indoor antenna like a
Winegard SS-3000?
If I decide to try an external antenna, would something like an RCA ANT 751R be a good choice?
What about a Winegard HD 7694P? I saw one of those at Fry's yesterday.
Are both of these complete overkill? I was also looking at something like a Winegard MS-1000, but it doesn't seem like I really need to worry about the omnidirectional nature. This would pretty much just be for the smaller footprint.
The other elephant in the room is problems with the tuners, but given a lot of people stating that they haven't had problems with the same equipment, I imagine the hardware is OK. As far as the software goes, it's really hard to tell if I've got a solid base to work from. When I go through the Media Center signal strength meters on my vbox cards, the signal seems to always show either 100% or 0% on the VBox Cards and 4 to 5 out of 5 on the HDHomeRun.
The only other stations I might even consider watching are either broadcasting from the same set of towers as the channels I've mentioned or are within 50 miles and 90 degrees away (I think I could pull in Spurs games from the San Antonio CW Affiliate), but I honestly don't care if I can't see them.
P.S. I can find 2.1 and 62.1 on scans but the picture usually isn't consistent.
