Old 8-Nov-2011, 7:17 PM   #1
oldjake135
what antenna would be best for me
http://www.tvfool.com/?option=com_wr...4bbac3990ab330 thanks for any help i am in Beaverton ont. Canada
oldjake135 is offline   Reply With Quote
Old 9-Nov-2011, 12:20 AM   #2
It looks as if there is limited digital deployment in your area. You would benefit from a large all channel antenna such as the Winegard HD8200U. A low noise preamp such as the Winegard HDP-269 or Antennas Direct CPA-19 would be needed to 'push' the signal down the coax.
Your report indicates 50 feet AGL as the mounting height for the antenna. Do you already have a tower?
Old 9-Nov-2011, 2:41 AM   #3
oldjake135
best antenna
yes i have a 50 ft, tower , 40 plus 10 ft pipe
Old 9-Nov-2011, 5:32 AM   #4
be236
Seems you're only about 90 km away from Toronto towers, so you should be having strong NM values... guess there must be lots of hills and trees inbetween...
be236 is offline   Reply With Quote
Old 9-Nov-2011, 1:56 PM   #5
oldjake135
signal
i get all the local channels, the american ones come and go i put up a 8 bay antenna was wondering if i changed it to a ccs 1843 antennna craft for deepfring area might help?
Old 9-Nov-2011, 3:11 PM   #6
The HD8200U has a bit more gain than the CCS-1843. Both would provide coverage of VHF frequencies the 8-bay does not.
I think you are too far from the US stations to get 100% reliable reception. Expect the weather and sun-spot activity to affect the signal propagation of all of those south of the border signals.
Old 9-Nov-2011, 5:58 PM   #7
oldjake135
antenna
thanks for getting back to me , i kind of thought the same
