Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates > TV Database Updates
Old 18-Apr-2010, 2:18 AM   #1
RingtailedFox
Detroit/Windsor lineup
heya, guys... got some suggestions for you:
WUDT-CA has now converted to digital as WUDT-LD, broadcasting on VHF 8 (23.1) with an effective radiated power of 300 watts.
WPXD-DT is in the process of getting ready to move to WKBD-TV's tower in Southfield, and switching from UHF 31 to UHF 50. I'm not sure when/if it will happen, though. Its effective radiated power on UHF 50 will be at 345 kW.
WUPW-DT and WNWO-DT both have construction permits to (nearly) double their power outputs to 110 kW to 200 kW (WUPW-DT) and 59 kW to 118 kW (WNWO-DT).
WLPC-LP has a construction permit to convert to digital on UHF 40 as WLPC-LD.
After August 31, 2011, Windsor/Detroit's digital lineup for canadian stations should look something like this:
CBET-DT: 9
CHWI-DT: 16
CIII-DT-22: 22
CHCH-DT-2: 24
CHWI-DT-60: 25
CICO-DT-32: 32
CBEFT-DT: 35
Power levels and directions (if any) are currently unknown.
RingtailedFox is offline   Reply With Quote
