Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates > TV Database Updates
Old 11-Mar-2010, 1:11 PM   #1
tvlurker
Ottawa, ON updates
CRC-DT-1 has been on the air testing intermittently recently. It's the Communications research Centre's experimental ATSC channel. It's been using PSIP 3.1
If you're updating networks as well, here are the networks for Ottawa, ON area stations:
digital:
CBOT-DT 25 (4.1) CBC
CBOFT-DT 22 (9.1) SRC
CRC-DT-2 46 (46.1) experimental
CFMT-DT-2 27 (27.1) OMNI1
CJMT-DT-2 66 (66.1) OMNI2
CRC-DT-1 38 (3.1) experimental
CKXT-DT-3 20 (20.1) SunTV
CRC-DT-3 46 (46.1) experimental
CRC-DT-4 46 (46.1) experimental
CRC-DT-5 46 (46.1) experimental
analog:
CBOT 4 CBC
CJOH-TV 13 CTV
CIII-TV-6 6 GTN
CIVO-TV 30 TQ
CBOFT 9 SRC
CICO-TV-24 24 TVO
CJMT-TV-2 14 OMNI2
CFMT-TV-2 60 OMNI1
CHRO-TV-43 43 A
CITY-TV-3 65 Ind
CHCH-TV-1 11 Ind
CHOT-TV 40 TVA
CITS-TV-1 32 Ind
CFGS-TV 34 V
CKWS-TV-3 36 CBC
CIII-TV-2 2 GTN
CKWS-TV-2 26 CBC
CJOH-TV-8 8 CTV
CHRO-TV 5 A
CKWS-TV 11 CBC
GTN=Global. ISTR that the IC database uses this abbreviation.
for the pending, WNYF-LD plans to have WWNY CBS on 28.1 and Fox-SD on 28.2, so I imagine you could brand this as CBS.
Analog WNYF-LP in Massena is Fox.
tvlurker is offline   Reply With Quote
Old 8-Apr-2010, 12:28 PM   #2
tvlurker
analog:
CICO-TV-24 24 TVO
Thanks for doing the update. I think it will be a great help to people in finding stations, since call letters are rarely used in imaging anymore.
I think there was a typo, as all the CICO stations are now currently erroneously listed in your database as TVA (a private, French-language network) instead of of TVO, the provincial educational network.
And while you're making updates, here are some more:
CBC: CHEX CBLT CBLN CBMT CBVET CBJET CBSET CBAT CBCT CBHT CBYT CBNT CBWT CBKT CBKST CBRT CBXT CKSA CBUT CKPR
SRC: CBFT CKRN CKSH CKTM CBVT CKRS CJBR CBGAT CBST CBAFT CBHFT CBLFT CBWFT CBKFT CBRFT CBXFT CBUFT
TQ: CIVM CIVQ CIVS CIVC CIVV CIVG CIVA CIVP
TVO: CICA CICE CICO
TFO: CHLF
CTV: CJCH CKCW CFCF CKCO CICI CHBX CKY CKCK CFQC CITL CFRN CFCN CIVT
GTN: CIHF CKMI CFGC CKND CHFD CFRE CFSK CITV CHAN CICT
A: CKVR CFPL CKNX CHWI CIVI
There are more, but this should cover a lot of ground.
Thanks again.
Last edited by tvlurker; 11-Apr-2010 at 4:24 AM. Reason: removed CHFD from CTV list - it is GTN only.
Old 11-Apr-2010, 4:22 AM   #3
tvlurker
Oops, for CHFD Thunder Bay, it's GTN and not CTV. (CHFD just switched affiliations in February, and I seem to have listed CHFD under both networks by mistake.
TVl
Old 12-Apr-2010, 1:51 PM   #4
tvlurker
More Canadian network data:
TVA: CFTM CHLT CHEM CFCM CJPM CFER CHOT CIMT CFEM CHAU
Old 22-May-2010, 10:21 AM   #5
mtownsend
Whew. Finally got all these fixes in. Thanks for all the updates. Hopefully we've got most of them in place correctly now.
