Old 4-Aug-2011, 10:05 PM   #1
anubis93611
Question Help in MORRO BAY
Hi guys, helping my brother set up a HDTV free from cable and i have this antenna up there now...
http://www.amazon.com/HDTV-Antenna-E...2495369&sr=1-9
What direction should it be, and he wants ABC the most.. Santa Barbara channel...
thanks!
Should we get a preamp?
PLEASE HELP!
http://www.tvfool.com/?option=com_wr...3e47ddcf1fc79f
anubis93611 is offline   Reply With Quote
Old 4-Aug-2011, 10:48 PM   #2
Start with the antenna facing due east per a compass.
Antennacraft published specifications for the U8000 claim 12.0 dBd gain. KEYT is predicted to be almost 16 dB below the theoretical level needed to 'see' it. The gain of the U8000 puts you at about -4 dB NM, The noise figure of an amplifier will make that worse, not better. The Antennas Direct CPA-18 and CPA-19 have noise figures of 2 dB or less, That would give you a net NM of -6 dB... You won't see KEYT with that antenna at that height.
To receive KEYT, you need a tower to get over the mountains. The enormous (155 lbs, 8' H X 16' W) Wade PB-82-BB claims 21 to 25 dBi of gain... That would theoretically put you in a position to 'see' KEYT... but I would expect reception to be on the edge at best.
Do you have OTA reception at your location? If so, have you considered sharing your antenna via products such as Sling Box or a HTPC that is accessible via a VPN connection over the internet?
Old 5-Aug-2011, 7:06 AM   #3
What Digital Tv stations/channels are being received now , and how many Tv's are connected?? KSBY-DT 15 NBC , KTAS-DT 34 Tel , K09UF 9 Telemundo , K16FC-D 16 PBS , KCOY-DT 19 CBS , KPMR 21 Univision , KKFX-CA 24 Fox , K28FK 50 Telefutura , KEYT-DT 27 ABC . Aim the antenna at about 95 degree magnetic compass. The front of the antenna is the V shaped metal receiving elements , the front of the antenna faces the Tv transmitters. http://kyes.com/antenna/pointing/pointing.html . Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695
Old 5-Aug-2011, 7:11 AM   #4
FOR NOW. For the strongest reception at the Tv. Have only one Tv connected. No splitters.
Old 5-Aug-2011, 2:45 PM   #5
To see if signal strengths increase to more usable strength. Like KEYT ABC from the Very Low -15.8 NM (dB) to a stronger signal of , say , - 5.0 NM (dB) or better yet , + 5.0 NM (dB) . Make two more radar plots at , 60 feet and 100 feet. Also you can go to the , >>Start MAPS<< part of tvfool and move the pointer around and change the height of the receive location to improve the reception. . Tv antennas receive the best when Nothing is blocking reception. The more the signal is blocked by , mountains , hills , buildings , trees , and etc. . the less will be received.
