For reception of the VHF low band channels 2 thru 6 and VHF high band channels 7 thru 13.
WMEB-DT REAL VHF channel 09 , virtual number (12.1-2) PBS.
WABI-TV REAL VHF channel 13 , virtual number (5.1-2) CBS and CW.
WLBZ REAL VHF channel 02 , virtual number (2.1-2) NBC and Local Weather.
WVII-DT REAL VHF channel 07 , virtual number (07.1-2/2) ABC and FOX / MyNetwork.
Above the roof install a Antenna Craft CS600 VHF antenna with a Antennas Direct CPA-19 preamp , aimed at about 40 degree magnetic compass direction.
Here is how to aim antennas ,
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at ,
http://www.hollandelectronics.com or
http://www.solidsignal.com.
Here are some but not all above the roof antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronard.com/34424560.html ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
Here are some places to buy antennas and etc. ,
http://www.solidsignal.com ,
http://www.antennacraft.net ,
http://www.amazon.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
