Hello! I'm hoping you can help recommend an attic antenna or solution to improve my OTA reception.
TV Fool Report:
http://www.tvfool.com/?option=com_wr...f1f08e0066c350
Desired Channels: Major networks (WRC/NBC, WTTG/Fox, WJLA/ABC, WUSA/CBS) + PBS (WHUT, WETA, WMPT)
Current Setup: I currently have a large outdoor antenna (5-6') in the attic (something like
this, but purchased many years ago at Radio Shack) attached to an HDHomeRun in my basement via 50' RG6 Coax Cable. I have a Antronix Residential Amplifier hooked to the bottom of the RG6 which also splits the cable into the back of the HD Homerun.
Current Signal Strength:
Code:
Call Net Chan VChan SigStren SigQual SymQual
WJLA ABC 7 7.1 100% 80% 100%
WUSA CBS 9 9.1 100% 75% 100%
WETA PBS 27 26.1 90% 90% 100%
WHUT PBS 33 32.1 90% 90-100% 100%
WTTG Fox 36 5.1 100% 80-95 100%
WMPT PBS 42 22.1 55% 50% 0%
WRC NBC 48 4.1 100 80-100 100
Current Notes:
CBS and Fox are a little flakey - I'd like to make them solid! I've also tried this GE Attic
Antenna and it did a little worse.
I look forward to your suggestions!
