Old 28-Sep-2011, 2:06 AM   #41
richnerd
The ANT-751 is only to test. I plan to purchase a larger antenna but I haven't gotten that far yet. I was working on the mounting location and relocating my home-run wiring. It's just when I moved the temp. ANT-751 to test (outside and about 7ft higher) I was surprised to get an over all signal loss across the board. After trying a number of things I finally installed the antenna in its original location (inside the attic) I got a much better signal inside the attic. BTW - I don't get WTAE with this antenna.
Currently have approx. 60-70ft of RG6 coax split to two tv's (additional 10-20ft). Hoping for a third tv down the road.
I understand I need a larger antenna I just had to purchase 4 tires for my vehicle so the larger antenna and pre-amp has been delayed a bit. It just concerned me of the signal loss when testing with my test antenna. I really don't have another good location outside.
Thanks for the replies.
richnerd is offline   Reply With Quote
