Old 11-Feb-2015, 3:20 AM   #41
Most likely, the difference in the wet vs dry reception was due to the soupy atmosphere and the wet terrain peaks out in front of you. The wet air will attenuated signals and reduce your fade margin and the wet terrain will slightly change how the signals diffract. Since your reception is barely holding onto the edge of the digital cliff by a few fingernails, it doesn't take very much change in propagation conditions to drop you off the edge.
Your channel 9 issue is with the other antenna. Either you'll have to search for and find a bit better spot for it or you're getting some kind of localized electrical/electronic interference that's masking its signal. A spectrum analyzer is the only effective tool for investigating that possibility.
Old 11-Feb-2015, 6:18 AM   #42
JGoodwin
It looks like channels 9 will be a hit or miss channel.
With the strong winds coming up I added two 7' long pieces of electrical conduit, flattened both ends and bolted it to the roof to the mast. Since it's an eve mount they go from the middle of the mast to the roof on each side of the peak.
After I installed them my channel scan went from 93 to 54. I lost half the channels. Is there any stiff material that I can use for supports that won't interfere with my signal?
JGoodwin is offline   Reply With Quote
