Old 2-Feb-2012, 4:08 AM   #21
WWBT 12 NBC is weak signal strength. And may not be received reliably. If you will like to try for reception of WWBT 12 NBC. Then install a Winegard HD7698P antenna with a CPA-19 preamp aimed at about 55 degree magnetic compass. The rest of the Richmond stations will be received with HD7698P antenna. WWBT is the one that may not have reliable reception.
Old 2-Feb-2012, 12:24 PM   #22
Check your Private Messages tvinthebush. It's in the upper right corner of this page.
Old 2-Feb-2012, 3:18 PM   #23
As Ground Ur Mast said awhile back , It is Ok to put information out in the open so every one can benefit.
Old 2-Feb-2012, 4:32 PM   #24
If you must know, I was making the OP aware of the AVS forum that has a local thread for his area so he can ask others in his immediate area what works for them. No reception secrets or amazing revelations going on behind the scenes.
