Old 14-Jun-2011, 2:21 PM   #21
gossamer
JC's recommendation of the HD7082P is a premium solution, not overkill, but appropriate if you want to see the lower powered stations, particularly those using 'real' low-VHF channel assignments.
It was doing a little reading, and learned that the low VHF and FM reduces the gain at the HD UHF band, which is what I really need. Do you think this is correct?
Thanks again,
Dave
gossamer is offline   Reply With Quote
Old 14-Jun-2011, 5:07 PM   #22
Thanks again,
Dave
Well.... almost. The low VHF channels, 2 through 6 are affected by radio noise more than high VHF and UHF channels. Propagation of these frequencies is also a problem at times, the upper atmosphere can act like a 'duct' or 'pipe', causing distant stations hundreds or thousands of miles away, to interfere with a station on the same channel. This makes reliable reception of the low VHF channels more difficult. I don't think it's correct to say that low VHF channels affect the gain of channels in the UHF band though.
FM stations can interfere with television reception. This often occurs when the FM signal is quite strong and the FM signal is 1/3, 1/5 or 1/7 the frequency of the TV channel. Amplifiers that are overloaded by strong signal(s) will distort the signals passing through the amplification circuit which will generate additional frequencies, usually 3, 5, 7 and other odd multiples of the input frequency.
Even though there are some challenges, it has been found, that the current DTV signal format used for OTA broadcasting in North America is more successful on high VHF and UHF channels.
On the plus side, high VHF and especially UHF antennas are quite a bit smaller than low VHF antennas. This makes it practical to build antennas with much more gain and directivity for channels 7 and higher.
Old 15-Jun-2011, 9:02 AM   #23
No the VHF and FM does not reduce the UHF. People say the craziest information. People get a little information and then twist it all out of shape. Here is the truth , Some antennas are designed as UHF only antennas and as such can be designed to have higher gain on the UHF only channels.
Old 16-Jun-2011, 2:30 PM   #24
gossamer
Originally Posted by John Candle View Post
No the VHF and FM does not reduce the UHF. People say the craziest information. People get a little information and then twist it all out of shape. Here is the truth , Some antennas are designed as UHF only antennas and as such can be designed to have higher gain on the UHF only channels , then a VHF/UHF FM antenna.
Interesting, thanks. For some reason I didn't see this response until I came back, because I have a follow-up question. First, it's not that I don't believe you (really, I do), but can you think of a reference online that can describe this further?
So the person that told me this information also told me that the two channels that I currently receive that are VHF (WABC and WPIX) are changing to UHF, so it is another reason why I shouldn't bother with a VHF antenna. Do you have any information about this? I've checked the FCC site to the best of my ability, and don't see any reference to either of them changing any time so.
I've also checked their wikipedia pages, and it seems like they have submitted for a change (as well as a signal increase), but have not been approved, and it's been more than 18mo.
Thanks for any ideas.
Dave
Old 16-Jun-2011, 4:29 PM   #25
Neither WABC nor WPIX have applied for nor hinted at moving from their VHF allocation to a UHF channel. Your source was mistaken.
In NYC, majors on VHF channels 7, 11, and 13 are set where they're at unless the FCC's re-packing proposal eventually affects them.
Old 16-Jun-2011, 7:43 PM   #26
It's up to you
In the end, it's your choice...
You have quite a bit of signal to work with so you don't need a huge 'deep fringe' antenna.
As you look at your TVF report, pay attention to the column 'Channel - Real'.
The HD7082P will very likely receive every channel from the top of the list down to the channels in the red section on an azimuth between 150° and 160°, with possible exception of those affected by co-channel or adjacent channel interference. The three antennas I suggested early on would also deliver a nearly similar lineup... the weaker signals being possible exceptions.
You have yet more options; You could choose not to receive any of the real channels 2 through 6. Given that choice, you could select an antenna that covers real channels 7 and higher. Ex. Winegard HD7964P, Antennacraft HBU-33 or HBU-44. These antennas will not have the long elements needed for real channel 2-6 reception.
If you are willing to forgo reliable reception of channels 2 through 13, you could opt for a very compact 2 or 4 bay UHF panel antenna such as the Antennas Direct DB-2 or DB-4. Antennacraft, Winegard and Channel Master have similar antennas.
Old 16-Jun-2011, 8:46 PM   #27
The Winegard HD7082P is designed to receive the low band tv channels 2 thru 6. Tv station WKOB-LD Real channel 2 has these digital sub channels , RTV http://www.myretrotv.com , TUFF TV http://www.tufftv.com , History Of Television Network http://www.hottvchannel.com
Old 16-Jun-2011, 9:42 PM   #28
You can compare antenna gain figures at , http://www.antennacraft.net compare the the , HD1850 , HD1800 , MXU59 , MXU47. And at http://www.winegarddirect.com compare the HD8200P and the HD7698P and the HD9095P and the HD9075P gain figures. And you can compare all the other antennas at these two manufactures.
Old 16-Jun-2011, 11:43 PM   #29
gossamer
I've read this over another dozen times, and I think I'm starting to get it.
You are basically saying that higher gain can be achieved for UHF with antennas that are not designed for the lower VHF frequencies. In my case, due to the proximity to so many surrounding transmitters, it's not a concern for me. Correct?
I think I might also be confusing channels 2-13 with real channels 2-13. I'm in NYC area, so channel 2 is WCBS. I believe you're referring to only the channels below 13 in the "Real" column of the TVF listing for my area, correct?
So this would include WABC, WPIX, WNET, correct?
Thanks,
Dave
Old 17-Jun-2011, 12:14 AM   #30
Unless we clearly indicate otherwise, I and the other regular posters here, speak only of the real channel numbers. This is because antenna selection is base on the real frequencies (channels) to be received. Antennas have no 'awareness' of virtual channel numbers, nor do they have any ability to distinguish between analog, digital, CW, AM, FM, SSB, PM or any other type of modulation. Virtual channel numbers help the broadcaster retain brand recognition established over many years... they also help confuse antenna selection.
WABC is on real channel 7 - conveniently that lines up with their VC#
WPIX is on real channel 11 - again, they conveniently were able to match the real and VC#
WNET is on real channel 13 - ditto
WCBS, WNBC, WWOR and many other did not manage to match real and virtual channels as they switched from analog to digital modulation.
The bottom line is, you need to check each one you are interested in.
Antennas are designed to operate over some range of frequencies determined by the intended application. Some antennas are only designed to operate over a narrow range of frequencies while other designs are intended for use over a wide range of frequencies. Antennas intended for low frequencies require longer elements and wider spacing than equal performing antennas at higher frequencies. Generally, an antenna designed to operate over a wide range of frequencies will be larger than one designed for a narrow range of frequencies.
It is easier to design a high gain UHF antenna that fits into a relatively small volume than a lower frequency VHF antenna. This is simply due to the physics involved. High gain Wifi antennas operate at frequencies well above the UHF band and as a result can be made far more compact... for the same reasons.
Old 17-Jun-2011, 12:18 AM   #31
WCBS Is transmitting on real channel UHF 33. Any way I have made my recommendation to receive the Tv channels at your location. You can choose your own antenna or go with what some else suggests.
Old 17-Jun-2011, 12:34 AM   #32
gossamer
Thanks for the explanation. FWIW, that is pretty much what I had understood, so I don't feel like I'm completely new at this :-)
Thanks,
Dave
Old 17-Jun-2011, 12:45 AM   #33
gossamer
John, thanks again. Once I realized the "Real" column was the one that should be used as the "real" reference, it was clear.
I checked out the websites for these domains, and it's unclear whether they broadcast in my area. Were you pointing these out because you know that they broadcast in the NYC area, and if so, can you point me to where I can find this out?
Thanks,
Dave
Old 17-Jun-2011, 2:57 AM   #34
I wonder if it would be Ok for you to go to the RTV web site and look the words Coverage Maps or even to call with a phone. And I wonder if it would be Ok to call the other networks. You can find out what is on the Tv stations by Googling the Tv stations call letters.
Last edited by John Candle; 19-Jun-2011 at 9:00 PM. Reason: Edited to remove non-constructive comments
Old 17-Jun-2011, 3:09 AM   #35
gossamer
John, I'm sorry you think I'm taking advantage of you. I did already check the RTV site (http://www.myretrotv.com/affiliates.html), and that is the only one that indicates they broadcast from NYC; the others do not.
I thought there was some table similar to the TVF listing that showed the channels you indicated, and when I didn't see RTV (or any of the others) in that list, I thought you were referring to someplace else.
I now see WSAH is one of their affiliates, but the historyoftelevision site seems only to broadcast in Texas, which is what confused me.
Thanks again for all your help.
Regards,
Dave
Last edited by mtownsend; 17-Jun-2011 at 7:54 AM. Reason: Edited to remove non-constructive comments
Old 17-Jun-2011, 4:12 AM   #36
I find RabbitEars.Info to be helpful when I need to know what is being carried on virtual channels.
Old 17-Jun-2011, 4:48 PM   #37
gossamer,
The network affiliation shown in the TVFool reports is for the main channel only, not the x.2, x.3, etc. subchannels. For low-power and independent stations that run many subs, its tough to have up-to-the-minute accurate information, so TVFool may leave that field blank. John was trying to point out to you that there is some programming available in the VHF Lo band, albeit special interest. There will be two other low-power stations that will be available in the future according to your report, one on channel 4 and one on channel 6. Do some searching at rabbitears.info to see if any of what they would have to offer might appeal to you.
Otherwise, you should go with the UHF/high-VHF antennas from Antennacraft and Winegard that @GroundUrMast recommended.
At the risk of spinning this out of control, I think your friend was confusing a couple of issues together. He was probably thinking about problems that can happen when HD receivers (either in the TV or as a separate box) get overloaded by nearby FM stations. In some cases, strong FM stations can set up interference in the high-VHF band that KOs reception of those particular stations. Strong signals of any type (FM, low/high VHF and UHF) can overload the receiver and cause interference all up and down the dial or simply force the tuner to scale back sensitivity and lose reception of weak stations.
I'm not sure if you remember FM radios in boom boxes, but if you got one near a broadcast tower, you would start to hear that station on multiple locations on the dial. That is a similar situation to what I was describing in the last paragraph.
Old 18-Jun-2011, 3:05 PM   #38
gossamer
Originally Posted by Dave Loudin View Post
gossamer,
Okay, thanks. The retrotv channel looks pretty compelling, but I don't otherwise think there is anything below channel 6 that I would be interested in.
You had said there were a couple of issues, but it's unclear what the second issue is. The first is that FM stations can set up interference in the high-VHF band, causing a potential degradation in signal quality of those channels, correct? If so, then what's the second issue?
If I choose an antenna that does not receive the frequencies below channel 6, am I avoiding this issue? Or is that range higher than channel 6?
Thanks,
Dave
Old 18-Jun-2011, 3:43 PM   #39
The second was strong signals desensitizing your tuner (the last sentence of what you quoted). I was implying that your friend was assigning the problems of strong signals with antenna design. This does not apply in your situation as far as I can tell, no matter what range of channels you want. Sounds like anything below RF 7 is not needed, so focus on the 7-69 designs that @GroundUrMast recommended. Go buy something!
Old 18-Jun-2011, 6:17 PM   #40
If I were in your shoes I would get the Winegard 7694 & mount it on the roof. It should easily power 1-3 sets & eliminate any concerns with FM interference.
If some channels pixelate or dropout with 3 sets connected, I would then add the Channel Master 3414 distribution amp; but only if needed. The 3414 will not overload with the signals at your location.
The LO VHF stations are only pushing 300 watts & the slightest bit of interference will likely make them susceptible to dropouts.(Especially overhead powerlines) Not worth the hassle IMO.
