Old 26-Mar-2017, 11:57 PM   #21
dbseeker
As always, the expertise here is superb. I will keep trying to wade through the antenna book. Like throwing mud up on a wall, eventually it will start sticking.
Thanks again!!
dbseeker is offline   Reply With Quote
Old 30-Jun-2017, 1:52 AM   #22
dbseeker
Appreciate GroundUR Mast for posting the 4NEC2 simulation of proposed design.
Since my math and physics background is 40 years old and dead brain cells in between,
what parameters in the simulation software would need to be altered to lift the lobes of reception and decrease the SWR? A better bra so to speak.
Is there any proven correlation between the software and real life design and reception?
Why do the lobes occur at the middle and below of the antenna design?
Shouldn't the whole surface of the antenna design generate some current since wave reception occurs throughout surface area?
Please pardon my novice questions. my background is not engineering.
thanks
Old 30-Jun-2017, 6:31 PM   #23
GroundUrMast had to select a frequency to model the antenna; he picked 584 MHz in the middle of the UHF band. Each dipole is 32" wide. That would make a halfwave dipole for 173 MHz, which is just below CH7. It would make a fullwave dipole (like for a bowtie antenna) for 346 MHz, which is between VHF-High and UHF.
The downward tilt is probably because the feed point is at the bottom. A downward tilt is used by TV transmitting antennas because the receiving antennas are usually at a lower elevation.
The main lobe is split in two because the two sides are out of phase as they would be with two antennas stacked side-by-side and fed out of phase to produce a null between the lobes. This is useful when you want to receive weak signals that are almost in the same direction as the local strong signals. It is called the Two-Antenna-Trick on hdtvprimer.com.
Oh, yes. First you have an idea, then you model it at the desired design frequency, and then you build the antenna and test it for proof of performance.
Most antennas can be modeled with the free software. Very complicated antennas require expensive software for accurate modeling.
The model is already making that assumption. In real use, the whole surface of the antenna might not be receiving an equal signal, this is called a non-uniform field.
You can see it happen when you move an antenna to a hot spot and note the increase in signal strength.
