Old 22-May-2014, 7:39 PM   #21
The Signal Strengths are Very Strong Signal Strengths at your reception
location.
The Green Reception Zone of the Tvfool Report.
The Tvfool Report Shows Reception is , LOS=Line Of Sight.
And the transmitters are all less then 6 miles away , except for 1 that is 28.1 miles away.
28.1 miles away is Not Far Away , 28.1 miles is Close. It is also Line Of Sight and the Signal Strength is Very Strong.
I Recommend Do Not , use any type or kind of antenna system amplifier.
Antenna system amplifiers , amplify the main signal and also amplify the , Multi-Path Tv Signals Bouncing All Around in the Attic and Bouncing All Around because of the Trees that are All Around.
Amplifying the Multi-Path Tv Signals Bouncing All Around will Most Likely Make Reception Worse.
Digital Tv Tuner Computer can Correct Multi-Path to a Degree and then the Tuners Computer is Over Loaded with Multi-Path and Dropouts and Loss of Signal Will Happen because Tuner Computer Can Not Lock On.
