Old 9-Jun-2017, 12:19 PM   #21
If I install an electric line to the concrete pad and put the power supply for the preamp in a weather proof enclosure would it help the preamp any all?
Probably not, but there is insufficient information available to comment more closely.
In any event, what is the CURRENT issue at hand?
Old 14-Jun-2017, 10:54 PM   #22
Brice52
WSFX was giving a problem. Since sent my first message it has been steady since
thanks
Brice52 is offline   Reply With Quote
Old 3-Dec-2020, 8:21 PM   #23
Brice52
Smile tower installed
Hi everybody
I just got antenna base poured on Nov 23.
That included 52 bags 60lbs) and 94 lbs of portland cement.
I lowered the ist 10 frf of tower and attached the middle 10ft and got a neighbor to help the top 10 to the middle one
I gotthe cabling and grounding done this past Monday
It was to windy Tuesday so the next day I walked it up and got it secured on the hinges.
the ant751r is on top at approx 33 ft
Pointed at64 degrees
The first scan got 50 found
30 minutes no signal
checked this morning and have signal
The problem was outlet that power inserter and signal distribution were plugged into.
Now signal levels
From Wilmington NC
Back edge of antenna
WWAY 100
WECT 100
WSFX 100
WUNJ 100
From Greenville Market
WITN 80
WNCT 100
WCTI 100
WPXU 100
You can from above posts that I have much reception from the tower except for WITN
Before the repack I received WITN at 100
WSFX anywhere from 88 to 92
But I did not have as stable system as have now
Two Weeks afterward I had cable and preamp failure
So orders a 150 rg6 cable and 35 ft rg6 cable
Pulled the 150 ft cable through about 122 ft of conduit 1 inch in diameter
installed a pingbingding preamp and back on line
