Old 4-Apr-2011, 9:32 PM   #1
from north
Red face Help! recommendation for a reliable TV antenna
With so much changes in technology, I am totally lost. just moved to Florida last week. Got myself a new TV. need help for a good, inexpensive, reliable antenna, or do I? the following link is the report generated by TVfool. Any advise is deeply appreciated.
http://www.tvfool.com/?option=com_wr...8d177855aeab80
from north is offline   Reply With Quote
Old 4-Apr-2011, 10:14 PM   #2
Your report indicates 8 feet AGL. You can try an inexpensive non-amplified indoor antenna, though I expect you will have some trouble with reliable reception especially if your home is constructed of materials which reflect or absorb television signals.
However, a Winegard HD7694P mounted on your roof or chimney, aimed at about 120° compass will provide a long list of programing choices.
Old 4-Apr-2011, 11:32 PM   #3
I agree with GUM on the Winegard HD7694P antenna. Read and understand this about , Real Digital Tv Channels , Virtual Digital Tv Channels , Analog Tv Channels ,http://forum.tvfool.com/showthread.php?t=695 , Here is how to point Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html , Here are places to buy Tv antennas and etc. , http://www.3starinc.com , http://www.solidsignal.com , http://www.starkelectronic.com , http://www.amazon.com . If you will like to try a Non amplified indoor Tv antenna , here the ones to use and the reasons why http://forum.tvfool.com/showthread.php?t=233
Old 5-Apr-2011, 3:29 AM   #4
from north
Many Thanks to both of you, and for such quick reply . will try the suggestions and report back the result.
