Old 20-Feb-2011, 5:14 AM   #1
alldredd
Antenna Suggestion for IA
I need some suggestions for a new antenna. I currently have a clearstream 2 with a winegard pre-amp. I have occasionally been able to pick up KWWL and KCRG, but both have been known to drop out and seem to be extremely sensitive to antenna direction. I have not been able to get KGAN with this setup. I'm considering buying a larger antenna, but I want to make sure it will get the job done. Here's my fool report:
http://www.tvfool.com/?option=com_wr...b9c959cfb2f586
thanks!
alldredd is offline   Reply With Quote
Old 20-Feb-2011, 10:17 AM   #2
TV Antennas and Reception
How many Tv's are connected?? What is the model # of the preamp??
Old 20-Feb-2011, 3:56 PM   #3
alldredd
Just one TV is connected now, but the antenna feed is run to pretty much every room in the house (6+ rooms). The TV is a RCA Rear projection from 2005. The preamp is winegard AP-8700.
Old 20-Feb-2011, 5:20 PM   #4
I suggest a Winegard HD7697P with No preamp. I suggest have the antenna connected to the one Tv , no splitters. .If more then one Tv is to be connected at other locations then use a distrabution amplifier such as the ChannelMaster CM3412 or CM3414. . Do not use the preamp it is likely to be overloaded by the strong signals of KWKB , KIIN , KFXA . Direct the antenna at about 340 magnetic compass. Here is how to aim Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . Read and understand this about , Real Digital Tv Channels , Virtual Digital Tv Channels , Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695 . Here are places to buy Tv antennas and etc.. http://www.solidsignal.com , http://www.3starinc.com , http://www.starkelectronic.com , http://www.amazon.com .. . Here are some online Tv guides , http://www.titantv.com , http://tvlistings.zap2it.com , http://television.aol.com
