Old 12-Apr-2019, 7:29 PM   #1
98mystique2
Pre-Amp/ Receiver suggestions
Finally made the jump to cut cable, trying to find out what type of preamp setup (or other ideas) to run.
20' and 30' AGL reports
http://www.tvfool.com/?option=com_wr...90385ab1cf819f
http://www.tvfool.com/?option=com_wr...90386ee95febf8
I'd previously had an HD home run for cable which I liked.
Looking to get some of the Chicago channels. Preferably WGN. I know with a medium antenna and standing on the roof with the antenna plugged directly into the tv I was able to get it so there is hope. In an effort to improve chances I bought a DB8e which should be in next week.
So questions
Will I be ok to run a high gain preamp with that or will I over power it with the "localer" Rockford channels? Hoping to install on the side of my house facing Chicago so the house can block Rockford and Madison channels.
Do I need an LTE filter ( I see some of the CM amps have them integrated) if I can see a cell tower less than 1/4 mile away?
Does it make more sense to just run a hd home run on the roof and run Ethernet into the house rather then coax? Where do I put a power inserter then too.
Can power inserters be 50 feet downstream?
98mystique2 is offline   Reply With Quote
Old 13-Apr-2019, 12:02 AM   #2
Your report links don't work. You did a copy and paste from the other thread, so the centers of the links are missing. Try these:
Old 13-Apr-2019, 1:10 AM   #3
98mystique2
Good catch, thanks, fixed
Old 13-Apr-2019, 1:44 AM   #4
Good test.
WBBM is one of your weaker Chicago channels and it is on VHF-High channel 12. The DB8E is designed primarily for UHF channels.
High gain (30 dB) preamps overload easily; go with a medium gain preamp (18 to 22 dB) like the Antennas Direct Juice. The house blocking the Rockford signals will help a lot, but there will still be some reflections off objects in front of the antenna. Try it first without a preamp, then add it.
Possibly not. However, the Juice preamp contains an internal LTE filter, but no FM filter. Not all cell carriers will be using the frequencies just above channel 37.
Hold off on that; it's a last resort. Keep it simple at first; you might want to feed a TV tuner on one TV from the antenna.
A preamp is designed to be close to the antenna. The power inserter is designed to be inside; 50 feet is OK. The coax that carries the signals down, also feeds the DC power up to the preamp.
Old 13-Apr-2019, 2:00 AM   #5
98mystique2
Interesting note that might be easiest for me. I have more Ethernet run in the house then coax. My last setup used the HD home run for the movie room computer and the Samsung has DLNA so it can access it, plus tv on the phone. Only concern I've got is heat and moisture with an outdoor install.
Old 13-Apr-2019, 2:04 AM   #6
It's your choice.
Chicago channel changes indicated by arrows:
https://www.rabbitears.info/market.p...&callsign=WBBM
Repack Plan for Chicago:
Rockford changes:
https://www.rabbitears.info/market.p...&callsign=WQRF
Rockford Repack:
Old 17-Apr-2019, 12:27 AM   #7
98mystique2
Good news, db8e came in today got it assembled hooked it up to the TV and get wgn even in the house (lots of dropouts). Bad news is I didn't do my research and Blackhawks have a contract with off air TV... So oh well but still get some fun tv! May look at ganging a high vhf and trying to get CBS too in this case.
Old 17-Apr-2019, 11:02 AM   #8
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
VHF hi antenna
if you do get a high VHF antenna, I recommend Stellar labs 30 - 2476. As far as antennas go, It's relatively inexpensive. From my own experience, I have a pair of them and both performed extremely well I'm 39 miles from Chicago, 47 miles Milwaukee and I get almost 90% I'm the farthest. .
https://www.newark.com/stellar-labs/...nna/dp/71Y5462
My only complaint is it is a lot of antenna for 1 VHF station from each city. Still, it looks like with your distances it will be exactly what you need in tandem with your already excellent UHF antenna. I was amazed one day I picked up hey station in Kalamazoo from across the lake which is about a hundred miles. Not perfect reception but it was pretty impressive to even pick it up.
I believe that antennas direct also sells a simple VHF add on antenna, but I'm not so impressed with it, for longer distances like yours.
