Old 16-Nov-2017, 2:38 PM   #21
Mo Man
Hi Rabbit73.
Thank you for the additional support and information. Yes, to help others learn, you have permission to show the photos as long as the exact location isn't known from the photos.
Thanks Rabbit73.
Mo
Mo Man is offline   Reply With Quote
Old 16-Nov-2017, 5:32 PM   #22
OK, thank you. I have removed the street name. If that isn't sufficient, I will delete if you say so.
Old 16-Nov-2017, 5:58 PM   #23
Kevin couldn't get any signals through the trees unless he aimed it way to the left to catch the signals coming around the trees:
He moved the antenna to a taller mast at the other end of the house.
olimazi, who lives in Branchburg NJ, SW of your location, has a similar NYC terrain problem and trees. His antenna aimed directly at a tree also:
GHammer also had a problem with trees. He tried 3 locations on his roof. The first was above the garage on the right end. The second was on a tripod at the left end as shown above. IIRC, the best location was on the roof peak at the center.
