Old 25-Jun-2017, 4:14 AM   #81
OTAFAN
Rca ant751
[QUOTE=rabbit73;57752]One secret is that the UHF driven element is a tetrapole, in the original version of the 751.
I have another question regarding the tetrapole on the RCA751 as to how it would correspond to an LPDA antenna such as AD Element.
I think I understand better now how it works on the 751, but how does an LPDA separate and combine UHF/VHF signals?
I have reread a Wikipedia article on the LPDA and it seems to me that it may have something to do with the fact that the dipoles are electrically connected directly into the boom(s) rather than the cross phased elements in the 751. But being the very much the amateur that I am in this field TV antenna electronics, I'm at a loss for a rather simple understanding. And since I'm considering adding an LPDA at my location, this would be very helpful.
Thanks again in advance for your kind help!
Old 25-Jun-2017, 4:04 PM   #82
The Tetrapole on the RCA ANT751R has two functions. First, it is the driven element (DE) for UHF signals. Second, it acts as a UHF/VHF combiner (UVSJ) in conjunction with the shorting stubs. There is no need for a UVSJ on the AD Element Antenna; it is designed for continuous coverage of UHF and VHF-High. What is curious is that a UVSJ is suggested as an accessory for the Element on the AD site. It would be useful if you only wanted to use the Element for VHF-High and have a separate UHF antenna.
The LPDA can be constructed either way. It can have two booms that are insulated from each other that also act as phasing lines to connect the elements together, or it can have one boom with the elements mounted on insulators and wires to connect the elements together. The two ways are electrically equivalent, but physically different.
Old 5-Oct-2017, 12:01 AM   #83
kennylive
Licencing fee
My guess is they didn't want to pay Denny's Antenna Service the licencing fee anymore.
Denny's has good stuff, but it's hard to pay $70 for his antenna, when you could buy it at Amazon or Menards for $40.
kennylive is offline   Reply With Quote
Old 6-Oct-2017, 11:31 PM   #84
OTAFAN
Rca ant751
Hi kennylive: Yes, before I posted this thread here, I emailed Denny's Antenna with a question about the RCA751, or rather his version of it, but he never replied back.
So I posted my question(s) here on TV Fool and received numerous replies and analysis, especially from rabbit73 who is very learned in this field of TV antenna electronics. I would encourage you to read as many of his threads as possible because you will learn a lot.
Anyway, stay tuned as they say because you usually clear reception for your issues here. Best,
Old 8-Oct-2017, 12:57 AM   #85
kennylive
I have seen Denny actually post on here, but he's pretty tight lipped about the gain is his antennas, and his arrangement with RCA. He plainly says he designed the EZ-HD and the Stacker with Winegard, and the 751R is exactly the same as the EZ-HD. Exactly.
Some years ago he commented that the 751 (no R) was a 7 through 69 antenna, but the EZ-HD had been re-tuned to 7 through 51, with improved gain. And then the 751R came out.
I really like his designs, but his prices are high, and it's a long way between the EZ-HD and the Stacker.
Old 8-Oct-2017, 2:09 AM   #86
OTAFAN
Rca ant751
Well, not knowing his handle here on TV Fool, it would be easy for me to miss his postings, kennylive. I would have thought he might have been interested in chiming in on this thread. It would have been interesting and helpful to have his input.
Not sure why the all the hush-hush about the gain of the 751. I found a couple of postings on the Net of about a "5" gain front to back average for both VHF/UHF. I even asked RCA Tech on their website and they gave me answers about everything else I asked for, but nothing regarding gain. Maybe rabbit73 will have some information. Actually, I just remember AdTech did some field testing with interesting results on this thread regarding gain. Yes, I see looking back now he sure did. So, there you go.
Anyway, Denny does indeed have an interesting website but pricey as you say.
Thanks for the reply kennylive. I just wish Denny would have replied to my email to him. But I understand my RCA751 here much more than when I first put it up. Its proven itself across the country in various, but usually moderate to stronger signal areas. Price to performance is good and sales show it so. Too bad about its most recent revision. Not quite as good. But I'm sure you read through this thread about that issue.
Old 28-Apr-2018, 2:43 AM   #87
gmcjetpilot
The gain and polar pattern for the Winegard HD7000R can be found in solid signal dot com under product info tabs >Downloads>Download Product Manual. I post the primary info below....
The HD7000R is very similar to the ANT751 (almost identical to the revised ANT7511 with following exception). It has four aerial extensions you can add to the VHF section to add coverage Low-VHF. As stated the RCA ANT751 was made by Winegard. The HD7000HD has a single piece boom like the original ANT751 (but no longer it has been divided into two to make for a smaller shipping/retail package). The mast mount is not on very back end off the boom like the original ANT751 but forward of the last two VHF aerials (like I think the ANT7511 is).
Net Weight 2.36 lbs.
Active Elements 10
Boom Length 32.75
Turning Radius 52.2
Maximum Width 100" (with aerial extensions on for low VHF)
Vertical Height 3"
Element Diameter 3/8"
CHANNEL
CH.2, CH.4, CH.6, CH.7, CH.9, CH.11, CH.13, CH.14, CH.32, CH.50, CH.69
dB gain over reference dipole
0.2, 1.8, 0.5, 5, 5, 5.3, 4.1, 3.6, 5.1, 6, 6
beamwidth at half power points
83°, 82°, 78°, 51°, 66°, 48°, 33°, 75°, 54°, 40°, 43°
front-to-back ratio
1dB, 3dB, 8.5dB, 12dB, 12.5dB, 4.5dB, 7dB, 10.5dB, 14dB, 11dB
Polar Plots
Chan 2-5 it is a figure eight front to back. The back lobe gets slightly smaller going from Chan 2 to 6. This is a pure dipole pattern.
Chan 7-13 Typical Fwd gain lobe, Back side either 3, 2 or 0 small lobes. Ch 13 has some side gain and one medium back lobe.
Chan 14--51: Going from 14 to 51 there is primary Fwd lobe going from wide to diminishing width. On back side it goes from smaller and smaller dual lobes at 135 degree and 225 degree.
I think the gain is low but more than adequate for a "urban" antenna with stations w/I 30 miles. The original RCA751 should be slightly better. My understanding is the new RCA7511 lost a little performance.
My original RCA751 gets LP (7.5KW) stations 9 miles out. That is similar to getting a flame thrower station at 30 miles. I have some obstacle issues (ridge, trees, high roof lines) to deal with and my experience is only TESTING. I had it on my "test stand" 18 feet in the air near my backyard tree line. It's going further away from the trees and up to 40 feet above ground. As of now I was getting SNR of 21-32 on all stations, including the lower powered stations. I actually have TWO ANT751's, which I am stacking. I have a nearby PBS station which is about 100-110 degrees off the primary direction for all other stations. The RCA pretty much NULLS PBS despite being close. No matter how much I play with direction I can't get low powered stations (which I watch) and PBS. Stacking two and combining I got great results on all stations. The dual stack test at 18 feet AGL was a success. At 40 feet above ground, further away from trees, I should be golden. Will raise the mast next weekend I hope. I have a new rotor but will save that for a SWL loop antenna... Rotors are great but to be avoided.
gmcjetpilot is offline   Reply With Quote
Old 28-Apr-2018, 4:31 AM   #88
OTAFAN
I'm glad you found your way through this thread to TV Fool, gmcjetpilot!
And thank you very much for the informative post above! I will bookmark it for future reference.
Here in greater LA/OC SoCal, there is going to be more action on low VHF due to the repack. Currently, I'm still using the RCA751 as my main outdoor antenna, but I'm looking at my options going forward so I will be able to watch some channels on those frequencies. There is a couple of affordable RCA antennas currently, but I'm waiting to see if anyone else offers something else on the market. I'm sure it will depend upon monetary considerations. So, thanks for pointing out the HD7000.
Please post any further testing results as you mentioned above when you can. I would be really interested in your findings.
This is a wonderful forum with excellent help from many posters. I'm sure you'll find it as helpful as I have.
Best OTA TV viewing.....
P.S. I too have been a avid SW/AM listener.
Old 28-Apr-2018, 11:57 AM   #89
Nascarken
Banned
Hello OTAFAN if you are looking too buy an outdoor tv antenna and won't it too last a lifetime.I suggest the Winegrud 8200U it's the best of the best if you are looking too buy
a hi and low vhf/uhf ANTENNA out there for the money.And what is your tv Fool report
Card say becuse you might want too buy a channel master amp.the way how I look at it
If you are going too spend money on an ANTENNA sistom .don't be cheap about it BUY the
best and have no regrets only a happy OTAFAN!!well good luck and have a good day.
Old 28-Apr-2018, 8:54 PM   #90
OTAFAN
Thank you, Nascarken for the recommendation! Wineguard 8200U is certainly a premium antenna, from what I could see on their website.
But I live in a strong signal area and don't need that large of an antenna or preamp. My RCA751 delivers anywhere between 25 to 36(mostly above 30), SNR on my Samsung signal meter, for around 180 received channels in several different languages, no less. So, the 8200U might be too much for my situation. But the HD7000 might fit the bill since it's just a bit larger version of the 751, two longer dipoles for low VHF. If I need more gain, I found the RCA 3037XR, which has more UHF/high & low VHF elements to it, but not too much larger or heavier than my current set up.
As I mentioned to gmcjetpilot, I'm waiting to see if any other options for low VHF come up, but as Rabbit73 has mentioned several times, it just depends on if the manufacturer can make money on producing a new antenna. I'm curious to see if Antennas Direct is going to come up with a low VHF option???
Thanks so much again for your kind reply, Nascarken! I appreciate your input and if you can think of anything else, please post.
Best to you!
Old 2-Feb-2019, 7:08 PM   #91
stephenson
Even though this post is well after the thread was completed, I wanted to thank everyone who participated - especially rabbit.
I just cut Cox cable - they raised price three months after they guaranteed a price for a year - three months!
http://www.tvfool.com/?option=com_wr...9038290b2ad724
The channels I really want are in the 20 mile range - especially PBS.
Attic mount - two options for ease and cost - both GE - 29884 and 36992 ... I like the 29884 as it looks a bit better build.
Thanks, again!
stephenson is offline   Reply With Quote
Old 3-Feb-2019, 3:17 AM   #92
Thank you for your kind words; you are welcome.
Attic mount
The signals in your report are very strong, but your report assumes your antenna will be outside and in the clear. However, since your antenna will be in the attic, the signals will be weaker. Aluminum siding and aluminum foil thermal barrier on the sheathing will block TV signals.
The 29884 is more sturdy.
Old 3-Feb-2019, 2:25 PM   #93
stephenson
Thanks, rabbit.
Started to order from amazon, but got stuck on which RG 6 .... been awhile since I beat this topic to death.
LOTS of marketing on coax ...i’ve installed 1000s of feet, but never found a notable “difference” ... I’ve also installed a zillion feet of RG 59, but further, er, back in time. I’ve had issues with sloppy connectors (mine and others), but never enough cable line loss for me to tell something was wrong.
Have reviewed the line loss charts for 18 awg ... they don’t differentiate whether it is solid copper or copper clad steel ... any real difference or just marketing? (Steel a bit stiffer, but ...)
Any real preference between manufacturers for RG 6? I do always try to buy USA sourced.
Btw - any difference in net signal between screw on a crimp on connectors?
Old 3-Feb-2019, 7:05 PM   #94
The attenuation loss is about the same for solid copper as it is for copper clad steel because the signals travel on the surface of the center conductor, which is called the "Skin Effect." The copper clad steel is stiffer which means that center conductor can migrate toward the shield in a tight radius bend and contact the shield, which is called "Cold Flow" of the plastic foam dielectric.
There usually isn't a need for the stiffer Quad shield coax, but if you have a long run up to a preamp at the antenna, the preamp voltage drop will be less with a solid copper center conductor and a Quad shield.
Not that I'm aware of, but the screw on connector isn't reliable, the hex crimp is OK, but the compression connector is the most waterproof IF you use the correct size compression connector for the RG6 you have selected.
Old 3-Feb-2019, 7:43 PM   #95
Nascarken
Banned
But when using an mast mount amp you should use SOLiD copper 18 Gauge
That is what channel master says to use with the 7777 amp
Good luck with your antenna set-up
Old 4-Feb-2019, 8:27 PM   #96
stephenson
rabbit and nascarken,
Thanks for advice - I've got source of solid copper through Amazon - and, did more reading of effects present when going around corners with copper clad steel.
I didn't mean to hijack the thread, but if we're ok with that can I inquire about connectors and tools ...
Over the many years, I have crimped with crimp tool, crimped with pliers, used screw on fittings ... never any substantive issues worse than having to pull connector off and do it again. However, I was performing below industry standards and may have even lost the odd few db here and there.
Standards have changed a bit over the last few years - way more folks now using compression tools and fittings - looks like it minimizes call backs - all good.
Lots of options on the market - on both tools and connectors. I've already got a spin type trimming tool, but most kits come with one. Can you recommend a compression kit or manufacturer? Doesn't matter if it has connectors with it although most do. Many comment on some kits as being toy-like - I always try and buy quality tools so want to avoid those.
Thanks!
Old 4-Feb-2019, 10:14 PM   #97
stephenson
Decided to pull trigger on an Ideal 30-793 I found on ebay for $25 ... looks like it will do most everything.
I also checked my leftover RG 6 and connectors - the screw on ones I had were too small for the some of the coax I had anyway ... ha! Will order some compression connectors ...
Old 9-Feb-2019, 7:55 PM   #98
stephenson
Equipment arrived - temp antenna range in living room ... 41 channels, clunky interface right now using either Channels or HD Homerun app on iPad to ScreenMirror to the 3rd gen AppleTV box ... once get 4th or 4K AppleTV, should be very nice, indeed - Channels is pretty easy and probably gonna be worth the one time $25 for the app. Free on mobile devices.
Up in the attic next week and will see what happens - I think a few more channels. Then question is: would I get more channels with an amp ...?
Old 10-Feb-2019, 5:07 PM   #99
stephenson
Here's relative signal strength numbers for my install so far - have the antenna sitting in family room about 30" off floor (center) ...
Figured out where to get the signal characteristics: Signal Strength/Signal Quality/Symbol Quality
3 - 77/98/100
5 - 79/96/100
10 - 70/68/100
15 - 88/98/100
18 - 67/90/100
19 - 73/98/100
21 - 82/98/100
23 - 94/98/100
33 - 72/90/100
35 - 76/98/100
42 - 38/48/none
44 - 91/98/100
55 - 72/98/100
Old 10-Feb-2019, 6:29 PM   #100
Nascarken
Banned
Ok and how far away are the TOWER'S forum your antenna RECEIVE?
