Old 17-Sep-2016, 5:37 AM   #1
SKYSCANNER
Question Antennas Direct 91XG Signal
I have the Antennas Direct 91XG UHF long range antenna. I also use the GE 24db gain booster. I have the antenna at around 37-38' with the elevation of 663. I can get 12 channels out of Springfield Missouri that is 90 miles away consistently with no drop out on most days. I have 65-75% signal during the day and around 95% after sundown. My mother has the same setup at about 30' high but her elevation is 643 and shes approx 3 tenths of a mile away from me. She only gets 6 of the channels and 3 of them fade in and out during the daytime hours but work great after sundown. She gets around 65% on 3 of them in the day and goes to above 80% some days after dark. But the main KY3 channel she wants KYTV out of Springfield Missouri she gets around 57% during the day and it don't come in most days during the daytime but works well after sundown. My question is if there is a stronger/better booster she can use that might help her out. I know height is her problem but a better booster may help. Any Ideas??
SKYSCANNER is offline   Reply With Quote
Old 17-Sep-2016, 5:56 AM   #2
SKYSCANNER
http://www.tvfool.com/?option=com_wr...e2cbf3ce8517f7
See I get the KYTV 3.1 3.2 3.3 all day long with mine but she don't. I see its in the grey area to.
The KSPR-DT She can get them during the day its 33.1 33.2 33.3 but says 19 on the chart.
I can get all these channels all day long. But at night I get a lot of extra ones to. Like the KOZL-TV I get 27.1 27.2 27.3 I also get all the K21JS 21.1 21.2 21.3 21.4 channels. All these work in the day also some but work the best at night.
Old 17-Sep-2016, 11:31 AM   #3
Jake V
Welcome, Skyscanner!
There is a warning on your TV Fool plot that the address was only resolved to the block level. That means it may or may not be accurate. I recommend preparing and posting a new TV Fool Report using the following directions: http://forum.tvfool.com/showthread.php?t=14508
Jake
Old 17-Sep-2016, 2:56 PM   #4
SKYSCANNER
30' and 40' Map it.
http://www.tvfool.com/?option=com_wr...e2cbc99eb003e9 30'
http://www.tvfool.com/?option=com_wr...e2cb95efa03c57 40'
KYTV 44 3.1 NBC is the main channel my mother is wanting to get.
Old 17-Sep-2016, 3:13 PM   #5
Is the report you gave in post #2 for your location and the reports you gave in post #4 for HER location?
Are there any trees or buildings in the signal path at her location?
Old 17-Sep-2016, 3:22 PM   #6
SKYSCANNER
Post 2 is just general area location. Post 4 is her exact location at 30' and 40' antenna height. We live in middle of nowhere there are trees everywhere. No buildings.
Old 17-Sep-2016, 3:27 PM   #7
SKYSCANNER
http://www.tvfool.com/?option=com_wr...e2cbda3de2d911
This is my location at 38' antenna height. But my elevation is 20' higher than hers.
Old 17-Sep-2016, 3:32 PM   #8
Thank you. I will study it and try to find a useful suggestion.
I will try to run a terrain profile derived from the report. If it isn't helpful, I might ask for the coordinates of her antenna in a PM from you if are willing.
Old 17-Sep-2016, 3:37 PM   #9
Her report, ending 3C57, shows KYTV NM -4.1 dB at 40 ft.
Your report, ending d911, shows KYTV NM -10.0 dB at 38 ft.
Am I reading that right?
Old 17-Sep-2016, 3:43 PM   #10
SKYSCANNER
Yes but I have no idea what that means.
Old 17-Sep-2016, 5:02 PM   #11
The strength of a signal on the tvfool report is given in two ways.
The first way shown is the Noise Margin, or NM for short. The TVFOOL FAQ says that a signal must have a NM of at least zero to be received, but you can add the antenna gain to make the NM more positive.
Both of the NMs are negative, so the -10.0 dB signal is weaker.
FAQs here:
http://www.tvfool.com/index.php?opti...ask=view&id=57
The signal Power in dBm is another way to state the strength of a signal, and can be measured with a signal level meter. Most tuners require a signal to be at least -85 dBm, but you can also add the antenna gain and the preamp gain to make it more positive (less negative) if it is weaker than -85 dBm on your report.
Old 17-Sep-2016, 5:12 PM   #12
The tvfool report takes elevation into consideration, but not trees
Old 17-Sep-2016, 5:16 PM   #13
I see you just started another thread. Is it for her location, your location, or for someone else?
Antenna and Booster Suggestions?
http://forum.tvfool.com/showthread.php?t=16096
Old 18-Sep-2016, 12:21 AM   #14
OK, I answered your other thread and am back on this one. I think I figured out where your mom is in Wideman. The satellite photo shows trees, but there are no leaves because of when the photo was taken. Trees block UHF signals:
scroll down to Trees and UHF
Her location is on the extreme fringe of KYTV coverage:
a closeup shows that her location is in a dead zone for the KYTV signal. Purple is very weak; no color is even weaker.
The terrain profile shows the interference from the curvature of the earth and the rough terrain.
Old 18-Sep-2016, 12:42 AM   #15
To improve her chances of better NBC reception, I suggest the 91XG with the front tilted up 5 to 10 degrees by trial-and-error testing, aimed at 323 degrees magnetic, and a Channel Master 7777 preamp. The antenna must be mounted in a location that does not block the signal with trees.
Old 18-Sep-2016, 1:13 AM   #16
Here is the Longley-Rice coverage map for KYTV on the FCC contour map for her area. Red color is very weak; no color is even weaker. Source link:
http://www.rabbitears.info/contour.p...2.941138888889
Old 18-Sep-2016, 1:35 AM   #17
SKYSCANNER
Please let us know how it works out on this same thread.
Best regards,
rabbit
Old 18-Sep-2016, 3:23 AM   #18
SKYSCANNER
Yes this is all together a different location. Its around 20 miles closer to the transmitters. Step dads place. You are correct on my mothers place. Thanks for the enlarged maps. I gotta figure out how to use the maps and tools better.
Old 20-Sep-2016, 1:04 AM   #19
Nascarken
Banned
We'll I had the same problem with the antennas Direct 91XG I firest used a channel master 7778 I Wood get. A CHANNEL 85Miles ALL night till 11:am loose IT in till 6pm so then I bought the channel master 7777amp and then I received ALL channels day or night with no dropouts
Old 20-Sep-2016, 3:50 PM   #20
SKYSCANNER
Thanks for the info!!
