Old 30-Aug-2016, 5:39 AM   #1
wado66
How do I read the topo map
We have a station, WSMV that most around here struggle to get. It is our NBC affiliate.
At 20ft it is 1 edge and at 30ft it is LOS.
That tells me I need my antenna at least at 30ft, correct?
Secondly, how do I read the image below?
Is my house on the left or right of the screenshot? What does the red, yellow and green mean?
Just confusing to me.
wado66 is offline   Reply With Quote
Old 30-Aug-2016, 11:53 AM   #2
No, the vast majority of antenna users have signal paths that are not LOS.
Signal Analysis FAQs: http://www.tvfool.com/index.php?opti...d=57&Itemid=89
Your location is represented as the point in the lower right where the gray (ground) meets the color. The broadcast antenna is represented by the white point near the upper left of the image.
Old 30-Aug-2016, 2:25 PM   #3
rickbb
Also note that the elevation profile, (not topo), is exaggerated to highlight the various hills, (terrain), between you and the tower. It will not show buildings and houses or any man made obstacle.
The colors indicate the signal strength, white being the strongest, blue/purple the weakest.
Old 30-Aug-2016, 4:03 PM   #4
I'm wondering why that is true. If the profile you show is for your location, then a tvfool report would look something like this:
http://www.tvfool.com/?option=com_wr...e2cbe6419c71d1
Does your tvfool report look like that?
Old 30-Aug-2016, 5:44 PM   #5
This is a topo map for White House, TN:
https://www.topoquest.com/map-detail..._cell_id=48695
Old 30-Aug-2016, 7:45 PM   #6
It looks like the WSMV signal grazes the terrain just before reaching your antenna. Any trees or buildings would affect it; the tvfool report doesn't take them into consideration.
That hill doesn't do any good for the signal:
The WSMV transmitter is in a different location than the other channels listed in green.
I wonder how many people are trying to use a UHF antenna for NBC.
There is a strong local FM transmitter that might interfere with reception of VHF-High channels.
http://www.fmfool.com/modeling/tmp/3...a/Radar-FM.png
If anyone is trying to use a preamp to receive NBC, the tuner will probably be overloaded by the first four channels on the tvfool report.
Old 30-Aug-2016, 9:30 PM   #7
wado66
My report looks similar.
I set it at 30ft.
http://www.tvfool.com/?option=com_wr...e2cbd4dffce5f3
Old 31-Aug-2016, 2:00 AM   #8
Thanks for the report. I did mine again at 30 feet, so I'm close enough that my profiles are valid.
Old 31-Aug-2016, 3:23 AM   #9
wado66
Now that I have figured out my height for my antenna, found a mount bracket and mast, all I need is my antenna.
I like the Channel Master antennas. (says the noob)
How do I determine which one would suit my needs? I think I have narrowed it down to a directional but it still leaves quite a few options.
Of all shown below which one would be my best choice? Or is there another ot there that would be better?
I was also thinking I should not get an amplifier from reading some posts.?
But go ahead and get an FM trap.
Thoughts on the above setup?
Old 31-Aug-2016, 12:15 PM   #10
wizwor
The difference between the Masterpiece and the Advantage antennas is construction quality. The number is range. So, for any given range, you choose based on construction quality vs cost. I would get the Masterpiece 100.
wizwor is offline   Reply With Quote
